10-28
I am printing an assembly as a unit on the plate, here is the progress from plate, to support removal to final clean up
way to push the print.... Nice piece Grendel. Wow!
Hi Grendel, wow that's some pretty sophisticated printing with multiple materials and components all produced at once, cool!
I'll post more detailed ones later. The script worked perfectly, thank you Michael. I output a 507 piece model using it and it just chewed through it no problem and imported perfectly with all the mesh separation.
Hi Grendel,
I used to work with American Marine Services who sent off a couple newt deepworkers and pilots to the gulf area. Maybe they are installing some of your devices!
Anyway..........
All my subsea equipment gets deployed between 500-12,000ft so we use unmanned ROV's for physical interaction if the primary control system has a problem. When I was in the Navy I worked at the Deep Submergence Unit and we had a couple Newt suits, Avalon, Mystic, Sea Cliff, Turtle and unmanned ROV's.
""I worked at the Deep Submergence Unit """""""""""
Intense stuff.... :o
Take care.
OK, here is a telescopic riser joint I am using as a classroom aid for my training program..
An actual TJ in service onboard an offshore rig. It is 65 feet long and 75,000lbs.
The render of one made with MOI
The build of the classroom model
The class model after clean up
Me likey!!!
Is that render still Carrara?
Yes it is....old habits die hard
I would have to say I don't think I've seen anybody render with Carrara as well as you..... I wish I was a fly on the wall in your work area for a bit....
Thanks for sharing.
LOL....You would hear a lot of cursing and screaming that DAZ has let the product languish technically since they purchased it to emphasize their....."content" delivery
It would just be ambient noise while I focus on what your doing.
Ray Dream was my first 3d modeler.
A quick print out of the CreatureBox JellyBean character, I used to paint warhammer figures years ago so I will break out my paints and get him colored up. The figure is about 4"" tall, I had to change the diameters on the arms cylinders and fingers to get them to be rigid enough to clean up...still has the same feel though
That is sure a nice printer you've got there.
It shows off your software nicely
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth curves
How do I add divide 1 - all and minimum .25 to the script?
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
SaveMultiSTL.js
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
10-28
