Full Version: Astonished free mechanical prog
Show messages:  1-7  8-27  28-47  48-67  68-75
1 Oct 2013   [#8] In reply to [#7]
so look at formats of SpaceClaim but it's no more a free product :)
http://files.spaceclaim.com/SupportedFormats.pdf
1 Oct 2013   [#9]
I know SpaceClaim :) but it's too expensive.
18 Mar 2015   [#10]
A last find some times for test it! :)
Works very fine! DesignSpark has a new version 2 !
Very similar than SpaceClaim !
Thx to Max Smirnov!
3 Apr 2015   [#11]
Do you know another speedy method against this "duplicate trick" for pushpull only a face from a volume after a fillet ?
3 Apr 2015   [#12] In reply to [#11]
There are many different push/pulls happening in that example there, so I'm not exactly sure which particular one you're trying to do.
But in MoI v3, you can use the Extrude command on a sub-selected face in a solid and get it to behave like many of those steps, here's an example:
To do that, select the face and then run Construct > Extrude.
3 Apr 2015   [#13] In reply to [#12]
Yes in Moi, Pushpull the "face" created after the Fillet is automatic! :)
The problem for me is make the same inside DesignPark!
And this at first view is impossible directly as I understand for the moment! ;)
Maybe there is a parameter to enable somethere...for make this possible...
3 Apr 2015   [#14] In reply to [#13]
Hi Pilou, sorry I don't know how to get that same behavior from SpaceClaim, it seems that it wants to move the fillet as well by default?
Maybe try holding down Ctrl or Alt when you do the pull, does that do anything differently?
You may need to ask in the DesignSpark or SpaceClaim forums to get a proper answer on that.
3 Apr 2015   [#15] In reply to [#14]
I have found! :)
But not sure that will work more speedy than my first "duplicate" above! :)
You must select strictly 3 edges!!! (1, 2, 4 don't work)
3 Apr 2015   [#16] In reply to [#15]
Hey Frenchy,
Just include the edge that belongs to the fillet in the selection. So, Select face, then Ctrl click the edge that you want to go along with the extrude.
3 Apr 2015   [#17] In reply to [#16]
You rocks! (click first the edge then Select face with Crtl works also! ;)
4 Apr 2015   [#18]
A little trick for the "Only read file STEP imported"!
Import the STEP file created in Moi ;)
Add a solid to the drawing (cube, cylinder, sphere, whatever).
Right click on the top-most name of the component tree (the name of the whole thing).
Unlock. Everything in the tree is now unlocked.
Just to change the not cuty Black color! :)
4 Apr 2015   [#19] In reply to [#18]
Frenchy's going Black Hat!!!!!!! Heaven help us........ :)
4 Apr 2015   [#20]
@Burr:)
Amazing thing: you have the export in PDF 3D!!!
So Moi format Step in PDF 3D ! ;) (or of course anything that you have in DesignSpark)
Inside DesignSpark : Menu File/ Save as PDF faceted Geometry
The file PDF3D: http://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub2.zip
4 Apr 2015   [#21]
cool
5 Apr 2015   [#22] In reply to [#11]
Direct editing... my software (Geomagic Design) does this too. Many software's do.
Design Spark isn't bad actually but just nowhere near as good as paid-for software.
7 Apr 2015   [#23]
In V2 Blend Function is missing so Install first V1 http://zwcad.com.tw/nick/FREE3D/
then V2
Edit : Seems this site is not more accssible!
8 Apr 2015   [#24]
And something else!
So you can make cotation of Moi object!
In 2D or 3D! Then export in DXF or PNG!
by Chri
Here direct export in the free DraftSight
9 Apr 2015   [#25]
10 Apr 2015   [#26]
As the blue plane frame is automatically hidden when you print
you must hide it like this if you want save an image PNG !
Select it = open context properties then disable Contour!
Sorry in French but in your version that will be in English! :)
So you can now have very easily have neat measures for Moi projects! :)
(even some strong fillets before new versions! ;)
11 Apr 2015   [#27]
Very exotic method for see the volume of an object!
You must have 2 volumes minimum
And for see the last of a serial you must copy it!!!
