Full Version: Astonished free mechanical prog
Show messages:  0-19  20-39  40-59  60-75
19 Sep 2013   [#1]
from SPaceClaim technology!
http://www.designspark.com/eng/page/mechanical
19 Sep 2013   [#2]
This is fantastic, and free !!!!!
Thank you
19 Sep 2013   [#3]
Thank you for the link Pilou.
My first reaction was, "It's free for now - How long before they charge for it?"
It's likely to remain free because it's main purpose is to sell electronic components via their 3D component library. Nice marketing strategy!
I especially like the option to add dimensioning to the drawing. I just went through a personal project using MoI where I machined several parts needed to modify a milling machine. MoI allowed me to visualize how everything fits together and it's certainly easier to test design concepts in 3D. I just had to manually add dimensions to my prints (I know this is on the list for MoI enhancements).
If I were doing this type of work for a living I'd use an expensive program, but for personal work MoI is my all-purpose multi-function tool.
Ed
19 Sep 2013   [#4]
Seems there step as Import ;)
So Moi compatible! :)
30 Sep 2013   [#5]
DesignSpark is useless like for me. It imports STEP files, but they're not editable. There is no any interesting file format to import. Useless...
30 Sep 2013   [#6] In reply to [#5]
If you have Moi just load the Step file and save it in SKP for use it inside DesignSparks ! ;)
If not you can use for example Free CAD for convert them in OBJ
http://www.freecadweb.org/wiki/index.php?title=Feature_list
then Load this OBJ inside Sketchup and save it as SKP ;)
http://sketchucation.com/forums/viewtopic.php?t=20584 (plugin obj import by TIG)
1 Oct 2013   [#7]
Yes, but I need NURBS, not mesh models in DesignSpark. As I said it's useless.
1 Oct 2013   [#8] In reply to [#7]
so look at formats of SpaceClaim but it's no more a free product :)
http://files.spaceclaim.com/SupportedFormats.pdf
1 Oct 2013   [#9]
I know SpaceClaim :) but it's too expensive.
18 Mar 2015   [#10]
A last find some times for test it! :)
Works very fine! DesignSpark has a new version 2 !
Very similar than SpaceClaim !
Thx to Max Smirnov!
3 Apr 2015   [#11]
Do you know another speedy method against this "duplicate trick" for pushpull only a face from a volume after a fillet ?
3 Apr 2015   [#12] In reply to [#11]
There are many different push/pulls happening in that example there, so I'm not exactly sure which particular one you're trying to do.
But in MoI v3, you can use the Extrude command on a sub-selected face in a solid and get it to behave like many of those steps, here's an example:
To do that, select the face and then run Construct > Extrude.
3 Apr 2015   [#13] In reply to [#12]
Yes in Moi, Pushpull the "face" created after the Fillet is automatic! :)
The problem for me is make the same inside DesignPark!
And this at first view is impossible directly as I understand for the moment! ;)
Maybe there is a parameter to enable somethere...for make this possible...
3 Apr 2015   [#14] In reply to [#13]
Hi Pilou, sorry I don't know how to get that same behavior from SpaceClaim, it seems that it wants to move the fillet as well by default?
Maybe try holding down Ctrl or Alt when you do the pull, does that do anything differently?
You may need to ask in the DesignSpark or SpaceClaim forums to get a proper answer on that.
3 Apr 2015   [#15] In reply to [#14]
I have found! :)
But not sure that will work more speedy than my first "duplicate" above! :)
You must select strictly 3 edges!!! (1, 2, 4 don't work)
3 Apr 2015   [#16] In reply to [#15]
Hey Frenchy,
Just include the edge that belongs to the fillet in the selection. So, Select face, then Ctrl click the edge that you want to go along with the extrude.
3 Apr 2015   [#17] In reply to [#16]
You rocks! (click first the edge then Select face with Crtl works also! ;)
4 Apr 2015   [#18]
A little trick for the "Only read file STEP imported"!
Import the STEP file created in Moi ;)
Add a solid to the drawing (cube, cylinder, sphere, whatever).
Right click on the top-most name of the component tree (the name of the whole thing).
Unlock. Everything in the tree is now unlocked.
Just to change the not cuty Black color! :)
4 Apr 2015   [#19] In reply to [#18]
Frenchy's going Black Hat!!!!!!! Heaven help us........ :)
4 Apr 2015   [#20]
@Burr:)
Amazing thing: you have the export in PDF 3D!!!
So Moi format Step in PDF 3D ! ;) (or of course anything that you have in DesignSpark)
Inside DesignSpark : Menu File/ Save as PDF faceted Geometry
The file PDF3D: http://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub2.zip
