6-25
26-44
..si figuri signor Burr....non c'รจ di che'.... :)
(..means in a kind way:you don't need to say excuse me)
Thanks for this pasta encyclopedia! :)
PS Seems the Stark form is an avatar of this! :)
Solved the camoflaged cone mystery.
Seems a second cone was hiding underneath.
Currently working on conical pasta from a Logarithmic2D script ceiling projection :-)
(And unwrap of a curve on a cone, using object list of lots of points.)
Here is an update to the ConeUnwrap script, which works on circular cones with axis perpendicular to the base.
It uses two buttons to select cone with apex vs conical frustum. (Using Michaels method in History command.)
Also the frustum unwrap line segments were redone, so the Unwrap is Sweep ready. (Do NOT use planar, as UV isocurve would likely not match.)
The script appears to work just fine under MoI4Dec2017beta.
I typed up some documentation which might be nice in a wiki...
A couple of remarks: Holes in the cone, or bites out of the cone, or curves on the cone, can be unwrapped using Flow, with the cone face and unwrap Sweep face.
Also, in the event the holes disrupt the base circle, slantseam, or top circle, substitutes can be created by the user, or use a substitute intact cone or frustum.
Edit 1/1/2018, Corrected 2 "bugs" in the script. New version is here: (post 33)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6175.33
Thanks a lot !
Work fine also under MoI V3
Hello Brian,
thanks for improving the script!
Have a nice day
Karsten
There is a defect in the script if the Frustum is "upside down."
In other words, if the selected "Base" circle of the Frustum is of smaller radius that the selected "Top" circle.
I think this can be corrected by exchanging the length values of the Top and Bottom in the code...
(The script does not unwrap cylinders.)
The Unwrap is called a "Net" by mathematicians.
Also, the script is leaving behind copies of the circles and slantseam line.
Corrected ConeUnwrap script.
For frustum, uses larger of the two selected circles as the Base, and removes the previously leftover, Base and Top Curves, and the SlantSeam line segment.
For cone and frustum, removes the previously leftover, Top Curve, and the SlantSeam line segment.
Edit: This is an OLD version, see post 39 below for latest version
_ConeUnwrap3_Jan1_2018.zip
Looks like I'll need to add a While loop to clean up extra geometry, for cancel button.
History button did not need it (?)
Hi Brian, yeah the Edit > History button doesn't do anything at all until you've pushed one of the 2 buttons in it. If you push Cancel instead it doesn't do anything so there isn't anything to clean up.
Also whether your script needs to do cleanup depends on how it's doing things - if it manually adds objects to the geometrydatabase itself then it will need to clean those up itself as well. But if it uses factory.update() to use the factory's built in object management mechanism and never calls factory.commit() then it should also get cleaned up automatically as well.
Thank you Michael.
I have not located a script which adds geometry, then does user picks, with Cancel not causing added geometry to remain.
I used .clone to reveal the top and bottom edges of the frustum, rather than a factory...
So far attempts to copyFactory the edges have not worked. It should be fairly easy :-) (I'll try again tonight.)
Removing the Cancel button from the display prevented it from being pushed, and leaving added geometry curves,
but maybe that is not a good solution if faulty geometry picks causes some hangup?
I see that Cancel of the BlendCap script will leave the selected edge, split into two parts. (They can be easily Merged back together.)
On another user picking topic regarding cone Base, or frustum Top and Base, picking:
For a cone, if the 2D Base curve is not a Closed, only part of the cone will be unwrapped to the Net.
For a frustum, the Top and Base curves must "Match."
Either both curves should be closed, otherwise both curves should end in the same line segments from Top to Bottom.
If the user selects the "wrong" Base curve, SlantSeam curve, or Top curve, or in the "wrong" order, the "wrong" unwrap (Net) will be displayed.
User verification that the Net is "correct" may be important.
There should be a lot of the default commands that would be examples of this, for example if you push Cancel in the Line command instead of finishing the second point pick it won't leave behind whatever line was showing.
That's ok, but yes if you are not using the factory update()/commit() mechanism it will be up to the script to do the cleanup, it won't happen automatically.
I've overcome my script problem with leaving extra circle and line geometry upon Cancel in the middle of the script.
Attempting to objectpicker select the Face and generate curves for the base/top/slantseam with Copy factory, was interfering with objectpicker selecting the curves/edges.
Why this has been so is still a mystery. The previous .clone code worked OK, but had the extra curve problem upon Cancel.
But by removing all of the objectpicker Select Face code, and not generating .clones or copies of edges, by removing that code, a mere click on the appropriate face, and then selecting the edges works just fine. It is too late to clean up the reduced size code tonight...
Attached is update to ConeUnwrap script.
The .js is considerably shorter.
The .htm is a little larger, with a bit more detail in the prompts.
The math is the same.
The orientation of the cone/frustum in space does not matter. Lengths are used, which are positive numbers.
The Bottom and Top of the frustum can be picked in either order. If Top Length is greater than Bottom Length, they are swapped.
Substitute Bottom, SlantLine, and Top circles can be used. A substitute Slant Line can be placed anywhere the SlantSeam would rotate around the center axis of the cone/frustum, which could help avoid holes. (A rewrap cone would have a relocated slantseam.)
A portion of a cone/frustum made by trimming with two SlantLines, can also be unwrapped to a Net, using matching Bottom arcs and Top (for frustum) arcs.
The Base and Top circles/arcs do need to be planar, and the cone/frustum "right circular."
Thanks again to Michael for his help and hints, and borrowed .js and .htm code :-)
With subsequent Flow unwrap of addition surface curves/edges/holes, the user will be responsible for verifying orientation of everything.
ps If all goes well, I'm going to do ObliqueConeUnwrap next, which will include elliptical or circular bases, or portions thereof, provided they are planar.
The equation will require numerical integration, which is already available in another script, and interpcurve.
The Oblique script should also work with cone-like objects with "radial" "ruffles" or wrinkles along the SlantLines (I think.)
The object will have to be developable, and have an apex point, although subsequent Flow should handle frustums.
(We'll have to see how the bottom edge turns out.)
_ConeUnwrap_Jan4_2018.zip
Thanks Brian !
After a lot of revision, here is the script _ObliqueConeUnwrap,
which creates a planar "Net" of the unwrap of a cone-like surface.
Reference:
https://plus.google.com/+NilesJohnson/posts/jCmg66wyo83
The MoI .pdf file "ObliqueConeWedgeCut" shows Niles' ascii drawing, in a more comprehensible fashion,
from which comes the equation he uses in the SAGE program, based upon the pythagorean equation.
dTheta = Math.sqrt( Math.pow( dS, 2 ) - Math.pow( dR, 2 )) / R;
The script should use 500, 1000, 2000, or more points, for a "brute force numerical integration."
The unwrap curve is not "perfect," but the "tolerance" changes for more points.
Rebuild can be used. It was not necessary after all, to use Trim in the script.
An ObliqueCone is easily made in MoI by extruding either a circle, or an ellipse, closed or open, with command Extrude, using "To point" and "Unlock direction" buttons. The iso-curves should be uniform. The cone can be a right circular cone.
A cone-like surface may also be made with Extrude / To point / Unlock direction, using some other curve.
These surfaces are also candidates for _ObliqueConeUnwrap.
Possible overlap is ignored by the script. The script just needs an apex point, and a base curve.
The base curve may be a standalone curve, or an edge, and be closed or open.
The base curve could be nonPlanar, or sinusoidal. After the unwrap, if a center line from the Net center point is added,
Network can create the planar surface, with nice iso-curves that can match the iso-curves of the cone-like surface.
Placing a sphere at the apex, and doing intersect, makes a base curve which could be nonplanar,
The unwrap may be an arc of a circle. All of the "radial" line segments are the same length, and dR is zero. dTheta = dS/R.
ObliqueConeWedgeCut.pdf
ObliqueEllipticalCone10.zip
_ObliqueConeUnwrap1_30_2018.zip
lot of work here !
it will be nice if you do a little video to show how to use this script
Also , i can't see your script in attachment
Thanks a lot.
Hi Finema,
Script is now uploaded. (I did a last minute minor edit.)
I'll have to learn how to do a video...I did buy Camtasia a while back...
I've decided that the sphere intersect of an elliptical oblique cone has radials at equal curve intervals (untrimmed segments), but that
delta theta angles are NOT quite equal(?).
Unwrap of Extrusion of Circle or Ellipse
Define a simple extrusion as being along a line, without using curved "Path," "To Point," or "Tapered" selections in MoI Extrude command.
For such extrusions, the top curve will be of the same character as the base curve.
Reference for "Net of oblique circular cylinder" Niles Johnson:
https://plus.google.com/+NilesJohnson/posts/WsmXBbu3Vu9
A right circular cylinder is the result of a simple extrusion of a circle along a line perpendicular to the plane of the base circle.
Similarly, a right elliptical cylinder is the result of the simple extrusion of an ellipse, perpendicular to the base ellipse.
The draft angle in these cases is 0 degrees, (plus or minus multiples of 180 degrees). (So angles are modulus +/- 180 degrees.)
For other draft angles, excluding the flat case of 90 degrees, "oblique" objects result.
An oblique circular cylinder is the result of extrusion with non-zero, and non-90 degree, draft angle, and has an elliptical cross section.
Slice planes parallel to the base result in iso-line circles parallel to, and equal to, the base circle.
An oblique elliptical cylinder is the result of extrusion of an ellipse with non-zero, non-90, draft angle.
Slice planes parallel to the base result in iso-line ellipses parallel to, and equal to, the base ellipse.
Curiously, note that removing the base and top of a circular cylinder with a matched pair of non-parallel slice planes, results in an oblique elliptical cylinder, not an oblique circular cylinder. An oblique elliptical cylinder has only one particular slicing angle which results in a circle, rather than some other ellipse.
The belt ellipse of an oblique circular cylinder...
6-25
26-44
