Show messages: All
1-6
7-15
Hi Max, although MoI's graphics engine supports it (as you've seen with the Grid and the early engine test image Pilou shows above), it's not yet something that can be set on an individual object level. Setting it on an object level has to be done carefully so as not to lead to a slowdown in display performance, that's mainly why it has not happened yet. It is something that I do plan on adding in the future.
Also one thing that needs to be resolved is whether the line type would be an object property or whether it would actually be a property that gets set on styles and then gets applied to objects by their style assignment. I'd probably try to do it as a style property but it would be good to know whether that would work ok for you or not.
Hi MIchael ...
I can't speak for Max, of course, but dashed lines per style would certainly work for my architectural work.
eric
Same reason as Eric.
To be honest I think there should be a dedicated small palette for that, as for me now styles = materials. More like in other CAD software: line types are a property apart.
Thank you very much for your attention
Hi Max,
It's not really universal that all other CAD software has line types only as an individual separate property, for example in AutoCAD the line type can be set on the layer and then applied to objects by their layer assignment...
Is there some particular reason why it would be helpful to have line types as a separate thing from styles? It seems like it would make sense in general if styles controlled things related to the visual display of the object, which seems related to line width and line types.
No reason actually, it's just that I am used to ArchiCAD for 2D drawing. It's fine for me to be a property of the style.
In AutoCAD, it can be set both as property of the layer, or individually on each element.
I know it's not a top-priority request, but thank you for your help!
Max.
Hello everyone,
I too am in need of a "Dotted Line" Style for architectural drawing purposes.
Was something ever implemented for this?
Take a look at this entiere thread!
https://moi3d.com/forum/index.php?webtag=MOI&msg=6518.1
Hi Berube,
> Hello everyone,
Sorry no, line styles are not fully implemented in MoI v4. It's something that I do want to add in the future but for now you would need to apply those in a 2D illustration program.
Show messages: All
1-6
7-15
