4-23
24-25
Thanks!
The method for change something is go to line by by line ? So hyper painful!
Or there is an special interface for change that ?
Thanx I'm glad you like it my customization.You have to change the background in options-view-colors background as Michael explained you.Here is the screenshot(bottom) of my background settings if you like to look like on mine screenshot.Then for the grid colors enter in to options-grid and fix it as you like.I will post you my settings if you like.Hope my screenshots and explanations helps you.
Regards from Nikola
Here is how to enter to ini file in moi to change you line color or surface color
Changing the colors and types of your grids
How to change your line color when you are in moi ini file with openned gimp and notepad in the same time.Find your desired color on color wheel and see rgb values (for example 0,255,255) and replace it in ini file with your desired color for your line.
My viewport background settings
ok :)
Seems there is a little problem here! ;)
letters are visible only when we are over the icones!
Are you asking about changing the UI colors or the grid here?
For the grid there is an interface for doing that under Options.
For buttons and things like that, you have to edit the moi.css file inside of a text editor, there are declarations of various rgb colors inside that file, you edit those rgb colors (yes, by editing the text) to change the UI.
Add this to the bottom of moi.css and it should make that particular text black again:
body.MenuBodyDark #Container moi\:StateButton .text {
color:black;
I had the same problem as Pilou.Now I will update my css file for downloading,it was the last piece of the puzzle.Thanx for your help Michael.
Regards Nikola
Update: For just in case here is the updated code of the ultradark moi ui for you to download,but also the above attachment now is replaced with this update.
ultradark moi by zenox3d.zip
<< For buttons and things like that, you have to edit the moi.css file inside of a text editor, there are declarations of various rgb colors inside that file, you edit those rgb colors (yes, by editing the text) to change the UI.
Yes that ! :)
But it's that who is very painful !
With friendly interface for choice colors that will be more funny! (like yours for the Gride and Background's color)
ANd with with some complet presets it will be the top! :=)
A general question :)
When we are inside the Menu Options...View Grid Snap etc
Say I am inside the menu Grid
Button "Restaure defaults" restaures the current menu Grid or all the menus? View Grid Snap etc
and about ShortCuts ? all are erased except default in case of a presume general reset?
It's for that i have never pressed this button! :)
Please don't press "RESTORE TO DEFAULTS" in options,cause it will change everything even your shortcut scripts.That's happends to me so I had to input my scripts from the start.
Regards from Nikola
Looks great guys - thanks!
<< Please don't press "RESTORE TO DEFAULTS" in options,cause it will change everything even your shortcut scripts.
If so maybe a second alert message for confirm will be necessay ?
or put the button Reset on the other side, because some time it's very easy to make an error of clic!
When you push the button a secondary dialog pops up that asks whether you want to restore defaults for the current section only or for everything:
If you have the grid section of the Options dialog open and then push "Current section only" on that dialog, only the grid settings should be reset.
It's probably not a bad idea to make a backup of your moi.ini file first before doing that anyway though, just in case. To make a backup, go to %AppData%\moi and make a copy of the moi.ini file in there.
Ok! Very good to know!
Great work zenox3d but is it for v3 or V2, or both of them because i tried with V2 and it doesn't work.
Thanks for your reply :)
It is for V3 sorry. I saw on the forum that we can use V3 beta for pro work so I thought most of the people use V3 with new tools and upgrades.Also i didn't know that V2 was programmed different then V3 beta.I will make update for the others too about this issue.
Regards from Zenox3d
@ Michael
Does it possible to have a color Selector inside the Dialog View Options for BarBody-SidePaneBody?
(it's easy to modify inside the Moi/UI/moi.Css file but...:)
Thank you
It's not really easy to do this because if you change the UI background it would be easy for text to become unreadable. It's not really easy to change the UI by only changing one single color like that, there are many different elements and colors involved in making a UI theme.
4-23
24-25
