Full Version: Script request, center cplane on export
Show messages: All  1-17  18-19
19 Oct 2012   [#18] In reply to [#15]
Tried ExportCentered2
Two things are not working.
1. Once the export in 3DM is done it doesn't revert the centered model (I need to cmd+Z)
2. It doesn't work if I try to output an OBJ, it doesn't display the meshing settings
I need this script specially for exporting to OBJ -> Cinema 4D :)
19 Oct 2012   [#19] In reply to [#18]
Hi DesuDeus, I just tested ExportCentered2 over here both in Windows and Mac versions and I can't reproduce any of those problems.
How are you installing and running it? Make sure that you are placing it into the \commands folder and to trigger it put in only: ExportCentered2 as the command name, nothing else like "script:" for this case.
