Full Version: UnwrapCurve plug-in
Show messages:  1-15  16-35  36-55  56-71
18 May 2012   [#36] In reply to [#35]
Wow, thanks Michael,
At some point, I may take you up on that. Right now, I am just working on basics, that are just fundamentals I need to understand to undertake the task. I had an intent in doing some work with stuff to "add-on" to MoI.
""""""Are you doing some kind of special project using OpenNURBS directly for your own program?""""""""""
Yes. I'm working on reading 3dm data to my own viewport to interact with MoI, with minimal user managment...Like, at the moment, I can proceed with IGES, because I can read IGES, but that extra step kindof defeats the whole mission of MoI. So, I have a bit of work to do with just the simple 3dm studies, before I know what my questions are. (Also, alot of my goals became your goals, so I'm still on the fence)
I may find my goals to be a bit above my head, but if I get my head above ground, then some of the questions may be very helpful...
The offer is very valuable to me.... Thank you for that.
Burr
18 May 2012   [#37] In reply to [#36]
Hi Burr, do you mean one of your goals with your own 3DM reader was to do a curve length unwrapper like this one here? Do you have some other specific stuff that you are trying to get done?
18 May 2012   [#38] In reply to [#37]
"""""""""do you mean one of your goals with your own 3DM reader was to do a curve length unwrapper like this one here?""""""""
No, totally unrelated... It was just a better understanding of what the underlying definition is.. Kindof like learning to read what I'm looking at when looking at the raw NURBS data. An analogy could be understanding how to write html with notepad instead of a wysiwyg editor. If I could write a 3dm file with notepad and then just compile it, I would be better at working with it!
20 May 2012   [#39]
This new function is also very cool for know the the length of curves ;)
20 May 2012   [#40]
Added :)
http://moiscript.weebly.com/unwrapcurve.html
1 Jun 2012   [#41]
How about Style Color preservation for the UnwrapCurve?
1 Jun 2012   [#42] In reply to [#41]
I've updated the plug-in attached to the original post with a new version that should do that now, you can get it from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5136.1
1 Jun 2012   [#43] In reply to [#42]
Thank you very much Michael!
5 Jul 2019   [#44] In reply to [#43]
More examples :)
Unwrap Curve script + Curve to Curve flow
Rebuild +Unwrap Curve script + Surface to Surface flow
5 Jul 2019   [#45]
Very cool pedagogic images!
13 May 2021   [#46] In reply to [#24]
Hello, I was not able to achieve what you had achieved!
I used arc 3pts to create a curved surface then I used unwrap curve to create a flat surface ( I tried to keep the number of points equal using rebuild command)
Then I created a textured solid and finally used Flow command!) but I was not able to achieve what you had achieved!
Could you please help?
Curved_Texture.3dm
13 May 2021   [#47] In reply to [#46]
Hi Psygorn, if you select your surface and turn on control points, you should see that the "underlying surface" of your flat surface looks like this:
It's a rectangular plane with trim curves on it - that's the kind of surface that will be generated by the Construct > Planar command.
For use with Flow in your case here you need to construct a flat surface where the "underlying surface" has the trapezoidal shape to it, not just the trim curves having a trapezoidal shape. There are a few different ways to do that, one would be to loft between 2 lines like this:
If you then turn on surface control points for that shape, you can see that the actual surface has that trapezoidal shape to it, it's not just the trim curves that have that shape:
If you make the base surface like that, and also move it right on the bottom of the shape to deform, you can then run the Flow command on it to get this result (you can hide the object to be deformed after launching the Flow command to make it easier to pick on the base surface):
Let me know if you're still not able to produce this result.
14 May 2021   [#48] In reply to [#47]
I got the same results :) Thank you!
However, I noticed if the lines that are used to create the trapezoid surface using loft command have more points (let's say 10) The results would be different.
Edit: Also is it possible to unwrap cylindrical or curved surfaces directly?
14 May 2021   [#49] In reply to [#47]
Update:
I had tried the same technique to create textured cylindrical shape, However the bumps end up inside of the cylindrical surface & not outside of it!
Note: I tried to click different corners of base surface and even rotated cylindrical surface along its height . I couldn't get desired result! what am I doing wrong?
Cylindrical_Texture.3dm
14 May 2021   [#50] In reply to [#49]
Hi Psygorn,
Use the option Flip normal surface in the Flow's option UI frame.
Have you tested it ?
14 May 2021   [#51] In reply to [#50]
Hi Phiro,
Yes, I did! but it was after I left my message here! It worked! :)
and I forgot to come back here and say it! Sorry, My bad!
Anyway I want to thank you for your reply :)
14 May 2021   [#52]
@ Michael,
Is it possible to have an "Offset" option in Flow UI?
So we can set an offset from the target surface? Is ti possible? I think it might come in handy!
14 May 2021   [#53] In reply to [#48]
There is a home-made script to unwrap cones or frustums. It may not be working for cylinders(?)
14 May 2021   [#54] In reply to [#51]
Hi Phiro,
Do u know how I could wrap those Voronoi cells around that curved surface(Target Surface)?
After performing flow command generated geometry looks messy and not neat like what Zooen did in his/her work! ( look for the thread "Ears of wheat")
Any help is appreciated :)
Curved_Surface_Texture.3dm
14 May 2021   [#55] In reply to [#53]
Honestly I thought the script/s are here in this thread but I couldn't find them! (I was looking for a Zip file)
Where could I find the mentioned home made Script/s?
