3-22
23-42
43-62
63-82
103-116
Still working on this but it's getting the time that's more of the problem here. Still shouldn't moan - Here's end of day progress ....
It's starting to come together well Martin!
I'm glad that you are having fun using MoI!
Thanks Michael. I deliberately chose a Lamborghini for this test as they have some sharp angular surfaces and subtle curves. I was thinking it would be a tough job for MoI, and my lack of skill at surface modelling has had me back peddling a few times, but fixing things and making little tweaks here and there is just so darn easy in MoI. I just did a test render in Rhino/Vray (couldn't resist a sneak peek), what was surprising though is that two of the surfaces that have been given some depth and weight to them report as bad ojects in Rhino, but they still render. The eventual conclusion to this project is Blender import and cycles render after seeing what the other guy achieved with his razor project.
Thanks Michael, glad you like it ... so far. I normally goof them up at some stage so this will be interesting to see if i can complete it.
All the best
Martin
Hi Martin,
WOw very start and a good model for moi.
Like to see more :)
My partner has been very demanding of my time so not much done over the last couple of days but i am detailing parts and adding volume to others....
Hi there,
You should put one color for your model and put another color for the background. this way we can see the model better.
It's not really a render as such, it's a matt finish that's like a clay model so you can see flaws in surface continuity easier, when i have more of the surfaces joined up then i will set it up better and do different shades before trying my luck with Blender & Cycles. But thanks for the feedback and encouragement ...
Martin
. wrong thread...
Why does this always seem to happen with me and Nurbs .... Time to start again me thinks with a new strategy, again
Any ideas are welcomed, and needed!
Martin
Hi Martin, you mean that those surfaces are not meeting up?
How are you creating them, by something like a sweep? If you're doing a sweep make sure that you're not doing something like only selecting a single profile just on one side of the sweep - if you want a sweep to match up in between 2 different shapes then you need to select both of those shapes as profiles for the sweep so the sweep has not just a start profile but an end profile as well.
When you have both a start and an end profile for the sweep, the sweep will gradually morph between the 2 shapes through the traversal of the sweep.
If you give it only a single profile on one side, then the other end of the sweep is generated purely by movement of that one starting profile along the sweep rails, and that may result in some other kind of shape at the end of the sweep.
If you're still having a problem with it or the above explanation does not make any sense to you maybe you could post an example single surface that's not working like you expected so that I can look at it and give you some advice.
Thanks for the offer of help Michael, I have this same problem with rhino too, which is why i came to MoI, so i know the problem is with me and methodology - No formal training so i must be missing something with the theory of it all :)
If you go back to the start of this thread you will see the two surfaces that have been zoomed in on on my last post, that they are sitting nicely aligned - The surfaces are either sweep or network surfaces, but they are fine. Once i start to slice up the surfaces (trim) for where the doors should be and to round off creases etc, then for whatever reason these surfaces start to move around as if by magic, I have tried ShrinkTrimmedSrf but it don't make a difference. The problem is I don't know when it happened or how, but because all the other trims, blends and fillets are done, and because i use surface edges rather then new curves where possible, the original alignments are gone.
On grab-04.jpg the right had trim line for the door has shifted the remaining surface segment from alignment without me noticing, but that one is easily repaired with control points or by deleting and using the new edge that got inserted during the trim process, the other surface - image4.jpg also shows how it has altered the surface curvature some how too.
The area shown in image2.jpg is perfectly fine in grab04.jpg despite having the trim going through part of the surface, but then some how during the process of;
Trim
Offset
Loft edges that need fillet
fillet corresponding surface
delete offset surface
join all surfaces created to keep everything as a group
Somewhere during that process it's changed it's position as if some sort of elasticity that held it in place has gone. I know it must be my technique. I don't single side sweep as i know it creates problems with continuity and accuracy, when i try doing vehicles I only use sweep, loft or network as you don't get many planar surfaces in vehicles as you already know. Is there a book you would recommend for me to read that covers Nurbs modelling rather than the maths, the theories and algorithms are way too heavy for my feeble brain ...
Many thanks
Martin
Finally got round to trying this vehicle again (been busy organising my wedding) - So this time i have not joined any surfaces and it's done as a patch work quilt thing. As can be seen I just have free-form surfaces with no depth or mass to them. If there are any experienced car modellers here, when should I trim ? should i Join before trimming or after ? Should fillets and Blends be done before trimming ?
With thanks ... Martin
Hi Martin, congrats on your upcoming wedding!
re: when to trim - that would likely depend on what particular piece you are planning on trimming.
Usually you woudl want to use trimming fairly early in the process, but you usually do trimming when you have modeled larger extended pieces to then remove some material from the single large piece to make the final boundaries. When you model in a kind of patchwork way where you actually have constructed individual surfaces that go around different contours and holes then usually that is something that handles features separately from doing trimming.
Usually though you will get a higher quality result buildling a smaller number of larger surface pieces and then trimming those to produce some of the edges in the final result rather than doing a patchwork type process. The patchwork process will make for a complex topology of a lot of interior edges in the final result and you will likely have a lot of pieces that come to shallow angles to one another - either of these things tends to make filleting difficult.
Thanks Michael - Can Moi take a number of sub surfaces and join them up so as to be able to do a Rebuild on the joined surfaces into a new single surface ? Or would be better off duplicating the edges as curves - joining them and then rebuilding those for new sweeps and networks ?
Martin
Hi Martin,
No, MoI does not yet have any mechanism for doing that, that is something that I want to add in the future though.
For now the main way to avoid making fragmented sub surfaces is to do the rebuild on your starting curves, so that you have longer initial starting curves that you use for creating the surfaces initially.
Thanks Michael. Guess that means another re-start and shift in logic then ... I thought it went too easy when i started this ... :)
Martin
Hi Martin, well not necessarily, depending on what you want to do next...
If you are already satisfied with how your model turned out with the patchwork method then that could be ok to keep it as-is.
But you mentioned filleting in particular - you could run into difficulties doing filleting with that current model. I'm not really sure which particular areas of the model you plan to fillet though, could you maybe give some more specific information on what the next steps are that you were planning to do with it?
Just in general vehicle modeling is one of the more challenging and advanced types of projects to undertake, by the way.
Thanks again Michael - The image below points to the areas to be trimmed. Those trimmed surfaces will then need to have chamfers or fillets added to them to create some depth and volume. I won't be attempting the interior, just need to get the outside looking right.
The image below has all of what needs to be rolled edges highlighted by MoI selection. These lines need to be rounded off rather than coming to a sharp edge. The other edges don't really need to be rounded as they are fairly accurate with the way that they just alter how light bounces across the surfaces.
I hope you can understand what it is i am trying to get across - Surfaces that are timmed then get the trimmed edge either offset or extruded as to have another surface to fillet. I choose fillets as they are more rounded than the blend which has that "s" type of shape to it and just don't work right in this situation. I have not found a way in MoI to extract what Rhino calls an isocurve which would have been more suitable for doing a subtle blend of the connecting sub surfaces to create the more massive surface.
Michael - "Just in general vehicle modeling is one of the more challenging and advanced types of projects to undertake, by the way."
Oh yes, I have been trying to master this art-form for years. I can do things like bottles, pistons, nuts n bolts and all that kind of modelling with no problems, that's why I can't grasp why I can't do vehicles. The only one i have managed to complete is an old 1950's bedford van as shown below.
Many thanks for the offer of help Michael - It's appreciated.
Martin
Hi Martin, so trimming those marked areas should not be a problem you can do the trim at any point I would think.
re: filleting - you will definitely have significant problems filleting the areas that you show there with this kind of fragmented "lots of separate sub patch" type modeling technique.
It's difficult in general for the filleter to handle cases where 2 surfaces come together at only a slight crease where they are like within 5 to 10 degrees of being smooth with one another but not actually totally smooth. That kind of only slight sharpness usually means that the fillets that would be generated are very small in size particularly in corner juncture areas where multiple fillets are colliding together. The whole process of intersecting and cutting back fillets that meet at a juncture point tends to get confused when shallow angle corners since the fillets are close to having overlapping surface areas instead of having a sharp intersection line between them, and it also causes problems when the corner patch itself is extremely thin or slivery.
Also having more complex topology with multiple edges coming together at one juncture point also makes it hard for the corner aptch to be generated, so like for example this area here in your model is unlikely to be filletable:
Also areas like this where you only want to smooth some edges and not all of them can also make it difficult for the area at the juncture to be fillable:
Usually the best way to generate smoothness in areas like that is to build them out of larger surfaces instead of using fragmented sub patches. You can also build a surface to be extended and broader than you actually need the final result to be and then trim away some parts of it - it can often be easier to shape a more simplified 4-sided extended surface rather than trying to build surfaces that all directly hug every outline of your final result.
Also although you mentioned you don't like Blend , it may be better route for connecting up some areas of a model like this rather than fillet.
You're basically into an area of quite advanced surface modeling doing this kind of stuff, and there are some kinds of advanced surfacing tools that MoI simply does not have yet, like a "MatchSrf" tool for editing one surface to make it smooth to another one at an untrimmed edge. You may get good results taking your model into Rhino and using Rhino's MatchSrf or Patch tools to edit some areas of the model to make some smoother areas.
I do plan on working on adding more of these advanced surfacing tools in MoI v3 but for now using Rhino alongside of MoI may be your best bet for doing advanced surface "trim and patch" type modeling.
3-22
23-42
43-62
63-82
103-116
