Full Version: Engrave tool
 25 Apr 2012
To: ALL
Hi Stevecim,
In your original post you were speaking of needing to boolean the continents away from the globe.. If all you want is lines, then you could probably do an "isect" command and generate outlines of the continents.
Look under construct-curve-isect and give that a whirl. Then you could also trim the globe surface with those curves and have continent surfaces too... Maybe run "ExplodeMove" on the seperated lot, to make a cool 3d image of the thing.
Reply
 25 Apr 2012
To: ALL
thanks Burrman, I'll give it a try :)
Reply
 25 Apr 2012
To: ALL
Earth.. ExplodeMove!!!!!
Reply
 25 Apr 2012
To: ALL
I love ZSurf. Used it quite a lot. Here are two examples:
http://grabcad.com/library/peugeot-badge-and-loge
http://grabcad.com/library/relief-with-frame
Reply
 25 Apr 2012
To: ALL
Nice work Sebastian, Like most MoI users here, your work is at a level I can only bream of reaching :)
here is what I done so far with Moi + ZSurf.
MWSnap061 2012-04-26, 16_02_46.jpg  MWSnap062 2012-04-26, 16_04_29.jpg  MWSnap063 2012-04-26, 16_05_12.jpg
Reply
 25 Apr 2012
To: ALL
Made an Antarctica from NASA map.
Outline is mostly ice...
Probably too many control points.
Planar and extrude work, but are very slow.
Not to scale...
Reply
 25 Apr 2012
To: ALL
a 3d pdf for the kids to learn from???
"Hey, where's antarctica???"
Very good johnny... :)
Reply
 29 Apr 2012
To: ALL
My two cents, from a cartographic point of view:
To create a correct globe in Moi, use a world-map that is "Unprojected" or is in the "Geographic projection". This is a world map with a 2:1 width/height ratio that will produce a correct globe.
Reply
 29 Apr 2012
To: ALL
thanks Dexter
Reply
Show messages:  1-13  14-22
Reply to All
Back to thread list | Login
© 2013 Project Beehive Forum
