Full Version: Gillette razor Mach3 recreated with moi3d
 28 Apr 2012
To: ALL
Blender can display normals. In the properties panel scroll down to mesh display and click on the little cubes under the word Normals: it displays vertexs and faces.
You can turn the imported faces into Ngons select vertices edges or face (X dissolve)
I find the default material that imports into blender with an OBJ is annoying but you can delete it.
I have also found importing a STL into blender is easier to deal with than an OBJ. just because of the material that is assigned to the mesh. It is easy to turn the tri's into quads (ALT-J)
to make normals consistent Ctrl-N
Oh yes, if you use blender 2.49 the OBJ importer imports the Ngons correctly (as seen in moi export preview window).
Reply
 29 Apr 2012
To: ALL
Hi Val2,
Thanks for that. (ALT-J) certainly cleans the mesh up nicely. I will try STL as well and see what happens.
Thanks for the tip.
Reply
Show messages:  1-2  3-22  23-24
Reply to All
Back to thread list | Login
© 2013 Project Beehive Forum
