Hello! How it is possible to connect correctly surface?
deka.3dm
Hi klickoff,
this one is easy, even I (a real newbie) can answer it. Since you already have the top surface like you want, you just need to extrude it in Z as much as you want. In the attached file, I copied your based surface on the side and extruded it 2 cm.
Regard,
Felix
deka01.3dm
Thanks. There is no I meant another and have thought up as.
deka_b.3dm
Nicely done!
