Show messages:  1-17  18-37  38-57  58-77  78-97  98-117  118-137  …  2638-2652
2 Jun 2017   [#58] In reply to [#57]
Excellent alternative to the free Sculptris http://pixologic.com/sculptris/
2 Jun 2017   [#59]
About the incredible online https://stephaneginier.com/archive/editSDF/
you must press the button "Apply" for validate a primitive before call a new one!
2 Jun 2017   [#60] In reply to [#59]
Hi Pilou!
Yes...I already know.
But I don't know how to export in obj format. it seems that it's available only a strange "glsl" (OpenGL) format,
and I don't know how to use it in order to import the geometry data into other software.
Do you know more ?
Marco (mkdm)
2 Jun 2017   [#61]
Hi Pilou and everyone.
WOOOOOOOWWWW !!
Found this : https://www.shadertoy.com/
I didn't know it. it can load "glsl" Pixel Shader file generated from "https://stephaneginier.com/archive/editSDF/" !
From its About page : "Shadertoy is the first application to allow developers all over the globe to push pixels from code to screen using WebGL since 2009."
And from Stackoverflow :
"ShaderToy is a tool for writing pixel shaders."
Look at this : http://pixelshaders.com/
It seems to be very very interesting...
See you.
Marco (mkdm)
P.S. See this video article : https://www.youtube.com/watch?v=TDZMSozKZ20
2 Jun 2017   [#62]
...Also this one is a very interesting article : http://area.autodesk.com/blogs/the-3ds-max-blog/introduction-to-pixel-shaders-using-glsl
2 Jun 2017   [#63]
Hi Pilou.
Look also at this! It's awesome on my 1080 Ti : https://www.shadertoy.com/view/llK3Dy
Ciao!
2 Jun 2017   [#64]
About the json format :)
there are some converters on line http://codebeautify.org/jsonviewer
alas the xlm resulting can't be reloaded inside Kerkythea (the only one for the moment that I remember that reload xlm file! :)
I believe that with Processing (a free coding program, you can reload json file format with some library installed and save as obj)
but i want find more simple! :)
In any case json format is reloaded by the editSDF itself!
2 Jun 2017   [#65] In reply to [#63]
Shadertoy
Sure sound + crazy images & shaders that is hyper cool!
(but seems little codes must be done ? ;)
Minutes 1.06- 1.26 of your link!
2 Jun 2017   [#66] In reply to [#65]
Ah ah ah....very funny this one. Look : https://www.shadertoy.com/view/XsBXWt
All in realtime on GPU!
@You : "...but seems little codes must be done ?..."
Oh yeah!! A lot of code.
But I totally don't know that programming language and math or OpenGL shaders aren't in my programming kwnoledge :)
(I write business app for android/ios)
It's only funny for me to watch how these guys are able to push out from GPU :)
See you.
2 Jun 2017   [#67] In reply to [#65]
Oh my God! I can't stop watching that stuff!!
Pilou, look at this insane and amazing realtime video : https://www.shadertoy.com/view/4dlyWX
Amazing!!!
OK. Over and out!
Ciao.
2 Jun 2017   [#68]
I believe that Unity can import json file! ;)
Alas I must reload unity for test that because the new update of Windows 10 invalidate my previous licence!
Relaoded but...
Not trivial for json, xml, so...good luck! :)
2 Jun 2017   [#69] In reply to [#68]
Thanks a lot Pilou for the info.
But...what about Unreal Engine and Json ?
I'm trying to use UE instead Unity....
2 Jun 2017   [#70] In reply to [#69]
Must be possible as like! ;)
Else with SDF :)
3 Jun 2017   [#71] In reply to [#69]
@Marco
http://www.mediafire.com/file/0oynrpi11opvkm7/OBJ+and+JSON+Converter+Program+2.0.zip
Features:
* Drag and drop support on executable.
* Easy to use program.
* Converts OBJ to JSON
* Converts (converted)JSON to OBJ
Recommended:
Windows 2000, XP, Vista, Win7
Alas for me during the convert "the Convertor has stopped to work" ... (surelly because I have Windows 10! :(
So a convertor on line (if existing) will be the solution!
4 Jun 2017   [#72]
Cool Beans!
I am amazed at the realtime nature of these. I have 2 Nvidia cards, I wonder if it uses both?
I really like this one:
https://www.shadertoy.com/view/4sXBRn
You can use your mouse to navigate the window. My display is set at 3440x1440 and it's stunning full screen. Thanks for sharing!
4 Jun 2017   [#73] In reply to [#72]
Hi Chipp.
@You : "...I am amazed at the realtime nature of these...."
Yeah...It's amazing how stunning are the visual results of most of the shaders of shadertoy.com!!!
I don'have a dual nvidia card in SLI but a single Gtx 1080 Ti on a very poor FullHD screen
but the results are absolutely amazing!!
I wonder how the performance could be even better with a Gsync QHD or 4K monitor.
i really love this one : https://www.shadertoy.com/view/MscXzn
It has slider to control the effects.
See you.
6 Jun 2017   [#74]
Shader online https://stephaneginier.com/archive/editSDF/
Like a fractal landscape in a second :)
So with Paint 3D on fbx moi's files...
6 Jun 2017   [#75]
Amazing isn't it ? :)
And you have a lot of another arrows and Rotate/Size gizmos!
Imagine when you mutiply these 3 objects! :D
And the different parameters!
this https://stephaneginier.com/archive/editSDF/ is a crazy thing!
15 Jun 2017   [#76]
Hi Pilou and everyone!
While I wait for the very first Moi's V4 beta I play with some nonsense doodles
made with 3D-Coat + Affinity Photo.
See you.
15 Jun 2017   [#77]
If you want some zany fluidified things try the free Verve! :)
http://www.taron.de/forum/
and of course you can use it for some cool textures!
