498-517
518-537
538-557
558-577
578-597
598-617
618-637
2698-2714
Interesting... :)
From a cool French Painting! ;)
Le Rêve du Douanier Rousseau ... 1910...
Winter-Spring (with my image from DesignSpark Mechanical! ;)
Beautiful!!
Pilou I have a little request... :)
If you want, could you generate some of this renderings with Magica, using one of the painting that I've done in Procreate (on iPad)?
If you can do it, I will sent you a PM with one of my paintings and you can post here your Magica results :)
If you cannot, no problem :)
Let me know. Thanks.
No problem it's 30 second for reload something...and you navigate as you want inside "your" image! ;)
Send me anything you want! :)
But why you don't try to make that with Magica ? i have yet took all for that!
I can make a little resume if you want! :)
MagicaVoxel installed
- Load somewhere the last version of SchematicToVox by Zarbuz :
https://github.com/Zarbuz/SchematicToVox/releases
- put your image png 256 colors in the same folder (not obliged but more easy)
- Put the line following inside the command line of windows (Logo Window + R) (for Windows 10 without Pilou of course ;)
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.2\SchematicToVox.exe --i heightmap.png --o output --hm 100 --color an image
That all : an file output.vox is created : just reload it inside Magica and have fun exploration!
Ps for a Mac I prefere say nothing... because i don't know if the Schematictovox.exe works with this OS !
With an old image created with the incredible free Verve for valide that is writed above! :) (30 seconds all process)
White sun
Hi PIlou!
Thanks a lot for your willingness!
And thanks a lot for your quick resume and short tutorial as well!
@You : "But why you don't try to make that with Magica ? i have yet took all for that!"
I'm sorry, but as I said, for the moment I don't have enough extra free time to devote to playing with these things, and actually you're certainly better than me and more skilled to create easily some cool stuff with Magica.
So, I'm going to send you a PM with two of my digital paintings.
I don't know if they're good for the conversion into a Magica's world.
Anyway, you will find a good way to use them into Magica.
Thanks a lot :)
Hi Pilou.
I tried to send you mi images via a PM but I get this error while sending:
"The following errors were encountered:
PILOU has opted out of receiving personal messages"
Curious because I receive some PM all days! :) (my PM box is not 100% full )
Try by email if you have always this PM alert message!
Hi Marco,
Maybe it's a bug in the error message - Marco, have you possibly disabled PM messages in your own settings? That's under forum Options > "Email & Privacy" > "Email and contact settings" > "Allow other users to send me personal messages".
Maybe if you have that disabled you won't be able to send a PM either.
Hi Michael.
@You: "...Maybe if you have that disabled you won't be able to send a PM either..."
Thanks for the tip :)
But I tried to search the options to enable PM again but I don't remember where it is.
Where is it?
Found it :)
I'm sorry, I read the previous message too fast ;)
Hi Pilou.
No problem with PM. I decided to keep it off.
I share here my two digital paintings that I did in Procreate (on iPad Pro).
If you want, play with them to create something fancy with Magica and share the results here on the Moi's forum :)
Both images are 5464 x 4096 pixels, so pretty big.
Image 1, called "String Theory" (in homage to one of the current theory of theoretical physics)
Original file to download:
https://monosnap.com/file/LJ4lKcRVtXPb2te5BqKHyqJ0uz4Jab
Preview in low res:
Image 2, called "Space Lollipop"
https://monosnap.com/file/NAZHprIvWBc1w2gIXIJH7FrpvVtvz2
Preview in low res:
Thanks a lot!!
Hi Marco,
why not try your images with 3DCoat (image to mesh) imho much better
(for such large files) than Magica. And you can use with 3DCoat more
than 256 colors ...
I will take these above because I doubt that the big size will works! (but i will test also the big ones...;)
@You: "...I doubt that the big size will works!!"
Maybe you can scale them down to the size you need.
Clearly you will lose details but for this kind of works I think it doesn't matter.
Hi Stefan.
Thanks a lot for the tip :)
Much appreciated.
One day I will try it ;)
Actually I temporarily abandoned almost all 3D strictly related stuff and in my spare free time I'm digging into free hand 2D digital painting.
But thanks anyway for your suggestion!
Ok works ;) (recall me "crop circles" ;)
(images are 960 * 800)
Inside with cubes = Spheres
WONDERFUL!!!
Very beautiful :)
Thank you so much!!
Very eye catching the second one but I didn't understand from which part of the original image is...
Could you upload also the generated .vox files?
Thanks a lot again.
So...some of my digital paintings could be useful to generate some fancy Magica stuff...
Good to know :)
Reload big size is not reasonnable! :)
498-517
518-537
538-557
558-577
578-597
598-617
618-637
2698-2714
