Show messages:  1-20  …  161-180  181-200  201-220  221-240  241-260  261-280  281-300  …  2641-2652
16 Jan 2018   [#221] In reply to [#219]
Check this Pilou : https://www.escapemotions.com/products/amberlight/index.php
I use it for a long time and although not fast enough for my liking, it's a great product.
Ciao!
16 Jan 2018   [#222]
Cool!
Remember this crazzy one online!
http://hirnsohle.de/test/fractalLab/
My little tests :)
16 Jan 2018   [#223] In reply to [#222]
Supercool!!! :)
Thanks for the reminder :)
22 Jan 2018   [#224]
Free Tree generator (only Windows) with settings!  :)
(There are some trees yet done! Export OBJ, dbo, x:)
No need to press the "Generate" button unless you put branches and leaves!
http://www.evolved-software.com/treeit/treeit
And you can of course load any PNG images with transparent background as "leaves"!
(even if not indicated in the drop-down menu files)
If you want to put native dds formats (Direct Draw Surface) you will have to use PaintNet to create some!
https://www.getpaint.net
Here my try! :)
22 Jan 2018   [#225] In reply to [#224]
Very nice!!
Thanks Pilou!
23 Jan 2018   [#226]
Maybe this can interest you! ;)
for replace SU 2018 Make who don't exist anymore in "local"! (so Free :)
Not yet tested because msi installer make me nuts!
even with these advices https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install-winpc/windows-10-error-message-another-installation-in/afc1a42b-a36d-46e7-a4ee-e86cf6fb9567?auth=1
https://www.bricsys.com/en-intl/shape/
Are you more lucky ?
22 videos ! Seems very complete and clear!
25 Jan 2018   [#227]
About free BricsCAD Shape
- The Push Pull is Multiple
- there is no rendering engine yet
(but the free SimLab Composer Light (maximum 1920 *1080) takes DWG files directly! :)
- It requires a small training because the Space Bar is used for intermediate validations in the functions!
- Ergonomically you can feel the Autocad progeny
- The shortcuts are "Text" : for example : REC and Space for a Rectangle!
- You can only use the icons!
- Fillets are much more powerful than in SketchUp!
- Shell, Knife in direct
- Circles are circles or pretend to be circles!
- Boolean operations are multiple and varied (we don't have them in SU Make)
- it can import SKP! So MOI3D !
-Export DWG (many version), DXF.
- It is Jean Nouvel who serves as the default target! ;)
Can have any form of perimeter!
26 Jan 2018   [#228]
About Shape above
You can use the Videos of Bim BricsCad modeling ( it's the same functions icons than Shape!
Normal it has the same BricsCad engine! ;)
Not really new things but for AutoCad world "Direct Modeling" yes! :)
A little rigid ergonomy in use! ;)
27 Jan 2018   [#229]
Last free SKetchUp in Local SketchUp 2017 Make https://www.sketchup.com/download/all
Some free other things for replace SU 2018
[url=http://moiscript.weebly.com/pcon-planner.html][u]PCon-Planner[/u][/url]
[url=http://moiscript.weebly.com/designspark.html][u]Design Spark[/u][/url] (Space Claim behind)
[url=https://github.com/Microvellum/Fluid-Designer][u]Fluid Designer[/u][/url] (Blender behind)
[url=http://www.sweethome3d.com/fr/][u]Sweet Home 3D[/u][/url]
[url=http://www.ptcfrance.com/cad/elements-direct/modeling/express][u]Creo Elements/Direct Modeling Express[/u][/url]
[url=https://www.teklabimsight.com][u]Tekla Bim Sight[/u][/url]
[url=http://www.formz.com/products/formzfree.html]FormZ Free[/url] SU like!
[url=http://www.formz.com/products/formzfree.html]Fibix[/url] (assemble rend mais ne crée pas sauf les terrains)
28 Jan 2018   [#230]
Merci beaucoup for keeping us up to date about interesting software, Pilou, much appreciated!
Have a nice Sunday everyone.
28 Jan 2018   [#231]
About Shape!
It's violent as a program, scabious fillets, multiple extrusions and boolean operations etc... but requires a certain "dexterity" for all that is on screen selection and choice of functions! :)
Objects from an XY frame were exploded once to separate and make them independent. Otherwise no multiple intersections!
The face of the pyramid is taken as a "cutting or not"object.
Clicking CTRL several times shows the different Cutting options.
We stop here on the cutting without keeping the extruded sharp object!
If one side of the pyramid is selected, you must hold down the CTRL key to select the complete pyramid and Skip/Drag to the different function icons!
29 Jan 2018   [#232]
After several attempts, it appears that FormZ Free is the closest to SketchUp Make in terms of organisation!
An interface a little less "fluid" but we manage much better than Shape's interface, which is a little bit of a puzzle! :-P
And there are some nice little ones, staircases, automatic roofs etc... as well as a practical volume "unfurler"!
A hint of Nurbs...
A "all-in-one" performance for not a dime! ;)
Allows import SKP, dwg, etc... and export STL and DAE (so re-loadable directly in SketchUp).
If you have better do not hesitate!
30 Jan 2018   [#233]
As a bonus, it's also operates as a Solid Modeler-- so that means it has great filleting and 3D prints.
I agree, it is a good program. I have it but haven't used it in years. Need to rethink that now that SU is off to the cloud soon.
30 Jan 2018   [#234] In reply to [#233]
<< so that means it has great filleting
Not in the "Free" version ! ;)
So some boolean operations (permited) for make it!
http://www.formz.com/featureslist/FeatureComparisonChart.html
30 Jan 2018   [#235]
Hi Guys and specially Pilou,
What about Pcon-Planner ! A great free software close to Sketchup for architecture and design and even has an internal rendering engine.
http://pcon-planner.com
https://youtu.be/mckPeCFvqX4
Cheers,
31 Jan 2018   [#236] In reply to [#235]
<< about Pcon-Planner !
was yet listed some posts above!!! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.229
Sure but its ergonomy for modeling is not directly friendly!
else
One button render very cool
Its function to import directly objects from producers very cool!
dwg / skp in every way very cool!
31 Jan 2018   [#237]
You'll probably like this Blender add-on, Pilou:
https://www.blendermarket.com/products/shape-generator
1 Feb 2018   [#238] In reply to [#237]
I am not yet genetically modified for use Blender! :)
1 Feb 2018   [#239]
2 years after a new "machine" (AlphaGo Zero) put a 100 to 0 against AlphaGo!
I leave you to imagine what it would be like against a poor human being! :)
And this having formed itself, just with the rules of the game!
Article: https://deepmind.com/blog/alphago-zero-learning-scratch/
And poignant video (Vo) of man's first fight against the "old AlphaGo".
I am waiting when "Deep learning" will be used for 3D creation! ;)
2 Feb 2018   [#240]
Cool, thanks for sharing, Pilou. I love keeping track of AI developments.
I thought you were also partly a Blender guy. :)
