19-38
39-47
Hi Burr,
By the sounds of things, what your wanting to do is not dissimilar to what I'm doing with jewellery models.
I bought 3D-Coat for the same reasons as you describe, but I'm still learning what's the best workflow with it.
Typically I've been exporting from MoI as an OBJ file & then importing it into 3DC within the Voxel Room.
This converts the OBJ into a Voxel & you can do what ever sculpting you want from there.
The newer versions of 3D-Coat now allow you to reduce the mesh when your doing the Export.
In my case this proved to be essential as my CAM program for milling had a limit to what the model size could be.
I'm also now using Sculptris & think of it in a similar way to how I see MoI...
...it's got a simple UI that allows you to just be creative.
And the Sculptris models will import just fine into the 3DC Voxel Room too.
HTH, Colin
The reduction of polygons in Zbrush ;) video
http://www.pixologic.com/zclassroom/homeroom/tutorial.php?lesson=decimation-master
Cool Colin,
That makes me more comfortable....
Here's a ring we cut on our 4th axis. I need to be able to make better geometry for the artwork. Our CAM package is a "wrapping type" so I have to make this stuff flat... I think the 3DCoat package is going to help us make a better/cleaner design.
And with free tools like Meshlab you can works on the mesh ;) the Mesh doctor :)
Repair, decimate etc...
http://meshlab.sourceforge.net/
Hey Burr,
Cant remember where I saw this, and I've never used it, and I know you dont need it... (lolz, kind of makes me wonder why i am typing this :D ) but this has always looked interesting to me.
http://www.cncwrapper.com/ Looks like one could get a cheap 3 axis toolpathing program and get to 4th axis the hard way with it... but for $20, thats a pretty cool option.
-Nick
That is a very cool tool and power in ZBrush. Does anyone know if 3dcoat can do this? I've searchred over there a bit and only found something related to bringing a poly model in to voxels...
I dont want to flood the MoI forum either with "how to use 3dcoat", but just looking at advice on which app will be best in the longrun.
Maybe I just need to know what to search for in 3dcoat.
LOL Nick!!!
cncwrapper.com =
"yo yo hip.....word up now.....(spit,spiff,p-poof pah, spit.....spit,spiff,p-poof pah, spit)
my name is....."
Hi Burr,
Great looking ring, Well done!!
""" Does anyone know if 3dcoat can do this? """
""" I've searchred over there a bit and only found something related to bringing a poly model in to voxels... """
The feature your looking for is called "Reduction" & is available when your doing the Export.
This is what I'm currently testing & it appears to be working OK...I still need to test cut something though.
There's also something similar where you can "Clone & Degrade" the model to reduce it's mesh.
The Clone & Degrade feature was what I was previously using prior doing the Export.
The new Reduction feature mentioned above, has to a larger degree saved me having to use the Clone & Degrade.
regards Colin
Hey Colin thanks. That sounds like what I was refering to. Actually the clone and degrade looks more like what ZBrush is doing with decimation. The zbrush one looks very powerful. There is much to learn about these as there is a bunch of stuff I am just unfamiliar with.
I'm going to loadup the demoes and start to poke around. At the very least, they look like they (either) will do the basis of what I'm after...I have to get in them though to know what my questions are...at this point, I'm not to up on what a UV map is as opposed to a Google Map!!! LOL (Just kidding)
We'll talk later...
I'll probably be running into lot's of this:
"Where the H*** is the "Lower polycount button"!!!! LOL
(No need to answer. A good illustration of what MoI is trying to avoid!)
I think my last question will be regarding my termonolgy when I enter the 3dcoat/ZBrush forums.
Is this statement correct???
"I am interested in only the underlying mesh and the export of it. I am not interested in UV mapping, Textures ( I interpret this to mean "simulating bumps and such with bitmaps") and various rendering mechanisms..
I will then take this discussion to the appropriate apps forum. Thanks!
Hi Burr,
Yes, that's correct - but you may want to specifically mention that you want to export to STL for physical model construction, that just helps to clarify what kind of stuff you are looking for even more.
Maybe something like:
"I am interested in only the underlying mesh and the export of it to STL for physical model construction. I am not interested in UV mapping, Textures and various rendering mechanisms.."
Texturing does involve applying bitmaps to objects - it can be used for simulating bumps but also for making areas of an object transparent, or also just putting colored patterns on things as well. But all texturing stuff is specific to rendering. There is not even any way within an STL file to have textures, an STL file is just a whole bunch of triangles and that's it.
Hi Burr, re: lower polycount
Isn't it obvious? You just need to hit the "Iso Parameterization Save Abstract Domain" a couple of times while holding down Alt + Scroll Lock. Then throw in a bit of "Quadric Edge Collapse Decimation (with texture)" for good measure.
"""Isn't it obvious? """""""""""
OF COURSE!! Why didnt I think of that. Some people just like pain!!! :o
Thanks Michael.
In a nutshell Zbrush is a very dense forest, filled with very clever tools but often implemented in a clunky way.
This along with countless procedures, settings, exceptions, prerequisites, etc.
If you manage sift out only the things you need and don't bother with all the rest of the stuff it's not so bad, but still not very easy at first.
No doubt that for organic modeling it's quite powerful.
Don't know much about 3dcoat though...
Marc
Yeah ZB seems like the big daddy, but I'm sure I would have a hard time using it. Demoing 3dcoat right now. Both apps do the type of modeling I'm after, but for me it will be the STL output (Too bad NURBS cant do this). Mostly I was wrong in the begining. Most artists seem to want to "decimate" and lower the polycount. I need to have as smooth of a surface as I can get physically. Fooling around with setting the resolutions of the model and the output right now...
Seems like for the CNC work, I wont be trying to bring my CAD model entirely into 3dcoat and working, it just degrades too much stuff with no options. Probably use it to create surfaces that I can toolpath in place of some finish passes on my CAD data, to get organic stuff cut in "particular areas"...
We'll see.
< Most artists seem to want to "decimate"
They don't want, they are obliged ;)
Except Zb and few other progs can't now manage such numbers of polygons :)
When you make animation you can't have these millions(billions) of polygons for make a render ;)
Same for make a Print 3D
etc...
Hi Burr,
Not sure, but maybe this thread I'd started might help you in some way?
http://moi3d.com/forum/index.php?webtag=MOI&msg=3140.1
Something you can do within 3D-Coat with Voxels is a Boolean Difference" type of thing.
It's called "Subtract from"...it subtracts an object on one Layer from another Layer.
This means you can bring in your basic Primitive model shape, convert to Voxels & do the surface details.
Then you can "Subtract" other objects as needed before you finally Export it out as a STL for CAM use.
This was something I'd been playing with when making ring bases & needing to sculpt on the top of them once in 3DC.
HTH, Colin
Hi Colin, looks like wrong link got into your post there, was this the one you wanted:
I'll update your message with that link.
Hi Frenchy,
Yes I see. There are many situation that will want to limit that stuff!! I guess mine is the opposite!!! :o Thanks again.
Colin,
Thanks. Yes that is the same place I am at. Fooling around with it now and will use this thread you posted as reference..
Thanks for fixing that.
regards Colin
19-38
39-47
