Full Version: Duplicated Solids.
 28 Jan
To: ALL
Hi Michael and Moiers,
Just wondering if there is any script, or maybe workaround, to easily delete duclicated volumes that perfectly overlap each other.
I did a mistake in one of my scene (quite huge with more than 1000 solids), and somehow I copy/paste the all scene twice (Yes I know .... .. .).
Now, let's say you don't have any undo available (because I save/quit for example), is it any way to quickly delete duplicated volumes ?
I had to click/select one solid, hide it , then delete every copys,... really huge time consuming to clean the whole scene .
Stuff like that often append in poly modeling, but there are often command/scripts to juste clean the whole mess.
Reply
 28 Jan
To: ALL
is for this case that a list of objects is usefull with hours dating !
Reply
 28 Jan
To: ALL
Hi PaQ,
After Paste, don't unselect the objects and give them a different name.
You will find the name in the objectbrowser.
Reply
 28 Jan
To: ALL
hi paq,
did you try the SelectParents-script?
http://kyticka.webzdarma.cz/3d/moi/#SelectParents
script:var gd = moi.geometryDatabase; var objs = gd.getSelectedObjects(); gd.deselectAll(); for ( var i = 0; i < objs.length; ++i ) { var parents = objs.item(i).getHistoryParents(); parents.setProperty( 'selected', true ); }
i duplicated a few solids on top of each other..selected the whole punch and ran the selectparents-script..ended up with just the "orginal" solids selected..
best of luck,
marco
Reply
 28 Jan
To: ALL
Hi PaQ, I think Marco's idea of using history for selection is your best bet.
Right now there is not any general mechanism for detecting or removing duplicates.
Reply
Reply to All
Back to thread list | Login
© 2010 Project Beehive Forum
