5-24
25-27
Hi Keris, yeah I know that looking at the nice clean n-gon wireframes starts to make the gears go in sub-d modelers heads about how they could leverage those meshes for sub-d work.
But it's really a pretty big mis-match... The best example I have to demonstrate it is this simple model here:
Generating a n-gon oriented mesh creates just a single n-gon on the top cap there, which is the correct result to get a minimal number of polygons and a wireframe that follows the original NURBS object structure. It's a very clean result, and perfect for rendering (and potentially non-subd direct polygon editing).
But it's totally not the right result for what you want - you would instead want to have the top broken up into something like a hundred little quads that radiated inwards from the edges. That's not like a minor tweak from the current result, it is a radically different result that is needed.
You're going to run into stuff like this all the time unless you greatly restrict the kinds of shapes that you actually attempt to model in MoI.
> I do think that some of my thoughts on tweaks from
> this post might be of some use;
Well, the problem is that probably some of them would come at a detriment to other situations.
For example:
quote:
First up, check the mesh for vertexes that only have two edges leaving them. These are useless and need deleting.
Here's an example of a NURBS trimmed plane created by drawing some curves and using the Planar command in MoI:
When saving to an n-gon mesh, the mesh result will be like this:
So notice here that every single vertex in this mesh only has two edges leaving from it, so according to what you wrote they should all be deleted and nothing should remain of this polygon?
The problem is that you're not really looking at the entire picture of what the mesher has to do, some of the things that would help for your particular goals are not able to be applied in general because they don't work universally.
One thing that sub-d modelers object to is adaptive subdivision - that's where the mesher changes levels of detail to put some more polygons in an area of a surface that has more curvature.
For example here:
There was a change in refinement level there at the red dot because the surface was going from a flat-ish area to a more curved area. When that happens there will be n-gons generated at the transition points.
It's not generally feasible to not have any adaptive refinement at all, because that would force surfaces that have curvature localized into a small area to get an extremely heavy mesh generated in their flat regions. For example a shape like this:
Trying to do that with no adaptive subdivision at all you have 2 choices - either you get a too dense mesh through the whole thing, or you get too sparse of a mesh through the whole thing and the small feature is not present at all.
So I understand that you don't build things like this, but it is the mesher's job to handle all kinds of situations like this without just blowing up...
I guess I'm just being a moron in trying to explain my thoughts here. Sorry Michael if I'm sounding like an idiot on repeat. ^_^;
But it's really a pretty big mis-match [...] You're going to run into stuff like this all the time unless you greatly restrict the kinds of shapes that you actually attempt to model in MoI.
Yes, such a shape would be impossible to output in this way. And I'd just not try to force it. My goal, really, is to leverage the mesh when and where I can, and in other places just output it looking good and deal with it another way (be that doing traditional retopology work or just baking the complex item onto another via a normal or displacement map). It's really a specialized thing for when and where I think I can cheat the system.
According to the letter of what I wrote, yes. But that actually wasn't my intention when writing it; I should have qualified that to mean "vetexes that only have two edges connected to them that are on the interior of a surface and not on the edge." Like a vertex just jutting up in the middle of a surface but not actually having it connected enough to keep the polygons from being shaped oddly. Really, after reading the rest of your message, I'm thinking that when these show up for me is when the adaptive subdivision would kick in, but I've made the settings such a coarse outliner case that it breaks what would have been an edge into just a lonely vertex. Really, it's more my fault for abusing the system in such a way.
I also actually created such a surface (with a complex N-gon edge) for use in creating a specific pattern of displacement on an object. I just exported it at a pretty high resolution and then just used ZBrush to project it onto the simpler SDS object. Worked out very well!
This is really so very true; we don't like it when this happens uncontrolled in the mesh (because it totally throws the smoothing off). I do fully understand why you would want it in MoI's primary meshing function (making renderable items). Just maybe a way to toggle it off for idiots like me.
So, yes, you're right in that MoI works as it should to achieve its intended goals. I'm fully aware I'm breaking the system in ways that are not intended or supported. And I've also been too presumptuous about my ideas on "improvements" to help this method. Again, sorry if I've sounded like I just don't "get it." I know you're trying to tell me (and everyone else) not to get their hopes set too high; and I also know I'm probably broaching on "but Daddy, why not?!" territory. I think I just grabbed onto an interesting (to me at least) thread and just didn't let go. I also didn't fully think through all the ramifications about trying to tweak MoI into working like this in any way other than a happy accident.
Hi Keris,
The problem is that you're going to easily end up with similar situations as that once you combine just a few more pieces together or have even a moderately complex object instead of a very simple one.
Even the example I posted was pretty simple...
Yes, well that's the problem that it is such a specialized thing that you are asking about, it would only apply to certain kinds of models, and for a special purpose target... That's a lot of specializations.
It can be detrimental to the wider body of normal users to have an important interface that they need to use to be clogged up with a whole bunch of controls that only apply to very specialized circumstances.
Every control that is added to the UI makes it more complex to use, and changing the behavior so that other situations will not work as well (like not having adaptive subdivision at all for example) is also detrimental for cases like I posted previously.
So when weighing things, it is hard to justify making an attempt to jury rig the mechanism with bailing wire, duct tape, and chewing gum to try and make it do something that it was not intended for.... I mean that could be possible if there were not detrimental side effects but there are.
You're probably going to have to post an example (if you had one previously in this thread, it's just too long for me to sort through sorry!) to explain more about what this means then.
You shouldn't normally have something that has only 2 edges connected to it internal to a surface and not at an edge. It can happen at an edge because edges can be curved differently from the surface they are on, like in the previous post I showed a plane that had a wiggly trim on it - that's the kind of situation where you can get further subdivision along an edge only which is I think the only place where you get only 2 edges connected to a vertex.
When internal subdivision happens you should get at least 3 edges going out from it, like this:
I guess the other kind of subdivision that you mentioned previously is when holes are split - but I don't know how to avoid that because most polygon formats do not support polygons with holes internal to them. It would be cool if it could analyze the holes with artificial intelligence and determine the absolute best pattern for splitting it, but it is difficult to program human intelligence and judgment into computer code.
But are you sure that these are not happening at an edge though?
If it actually was internal to the surface and not along an edge then that could possibly be something I could actually improve...
If you have an example image of this particular case, please post it so I can understand it better.
If it is happening at an edge, maybe I could still do something about it by trying to avoid edge refinement by some amount in the case of a coarse angle being used.
Re: Toggle off adaptive refinement - I've thought some about doing that, but it also opens up some difficulty... Like I mentioned previously there are actually 2 choices - should it extend refinement throughout a surface so that the whole surface becomes more finely subdivided? Or should it avoid refinement in which case small details like that little bump in the middle of a broad flat surface may be eliminated? Also avoiding refinement would have a major side effect of kind of partially disabling all the other parameter values. For example generally there is a starting base mesh which is then refined adaptively to ensure that all places on it match the tolerances that you asked for. Without the refinement your result will not fully match the tolerance values that you specified. It is rather difficult to portray this kind of semi-disabling of the tolerance values in the UI.
5-24
25-27
