Show messages: All
1-5
6-7
Hi fiveelement, which build of MoI are you using?
It looks like the current RebuildCurve script uses a function that is only in the most recent Oct-19 v2 beta. So that may be the problem.
Try the slightly older version attached here and see if that works.
Also for the next v2 beta there will also be a new Rebuild command that will be a part of the regular MoI install.
RebuildCurve.zip
Hi Michael
The problem was solved
Perhaps,MoI is previous version.
Thanks you!
Show messages: All
1-5
6-7
