5-23
Something is still not correct Michael.
The match for the second gear is on the outside not the inside. Also in theory the second lot of gears could be on a straight line.
Will work on it some and see if I can come up with some diagramatic illustrations--I may find solutions on the way?
Hi Brian, well the one in Petr's associated image that you were asking about is curved, not flat. I assume that he used this method to make that particular image.
A flat piece is certainly a common kind of gear structure, but as far as I could tell that command is not currently set up to create flat pieces, just curved gears.
It's probably not too difficult to draw a flat piece by hand though, you would do something like draw one tooth and then use Transform / Array / Dir to replicate it...
If you can make a diagram of what you want to create I should be able to show you the steps for it.
My profile could ,rather than be a straight line, be a positive or negative curve.
I just can not see a "correct" solution to making "adjusting distance" be an acceptable result?
Hi Brian, I'd do something like this:
Start with one tooth which is slightly narrowed from the other gear, and draw a line off of one part of it. Then do a Transform / Array / Dir, and pick the 2 points as indicated here:
That will create this:
You may need to adjust the length of that line hanging off to the side, I made it a bit shorter or longer until I got a nice fit. It looks like you have the equivalent of a rather long line in yours.
Then you can repeat the array dir, but reversing the order of the points to do an array to the other side, then add one extra little line and then that straight part can be closed off and finished:
Also, it will be hard to adjust it to make it fit nicely if you have it far away from it - push the tooth right up against the gear so you can more easily tell when you've got a good fit from your adjustements.
Thanks Michael. It was the complex way I thought was not necessary. Am I forgetting the very simple way of doing this in other apps? (On the law of averages--I am wrong!)
Hi Brian, the only more simple way that I can think of is if a program has a specialized command to create that part.
Otherwise drawing one tooth like that and replicating it is the most simple way that I know of anyway...
These Gear Fonts can be good fun to use in MoI.
Is there anywhere I could send the zip file for access?
Hi Brian, those look cool - you should be able to post a .zip file as an attachment to a message right here as long as it is not too huge.
OK it did--all have fun.
Brian
This is a rewritten version of the original Spur Gear script
This Script has excellent examples of how to code for multiple factories, in htm, if I can understand them.
I see that the function factory(factoryname) is being passed more (parameter) arguments than are declared.
The "argument object "is being used to process the arguments.
http://www.w3schools.com/js/js_function_parameters.asp
The techniques of this script are perfect for a polyskelions script, because I need 2 interpcurve factories.
I've got the two curves coded up already.
The join and circular array will come in handy also. And sliders.
Hi Brian
This factory function trick I found in the old SpurGear script. :)
Unfortunatelly, I can't find the original thread and the author name of this script.
Hi Max,
Could you please explain what the re-written spur gear script does?
See post #3 re Petr ?
I've been looking for a formula for internal spur gears...with ambiguous results so far.
I saw the factory function somewhere else awhile back.
OnClick is used again.
Just found this gear generator that might be useful to someone? http://geargenerator.com
BW
Keith
Thanks a lot Keith!
Very useful.
Ciao!
Interesting! Thanks! : - )
Hello, I made an update to the gear script.
It adds a checkbox for planetary gears, and creates properly-meshing ring-gear.
Simply
Addendum and
Dedendum values are switched.
Gear.v1.1.2021.03.22.zip
5-23
