I want to make a help window. Initially I was writing the help text in the called window. And everything worked fine.
But now I want to make the translation of the text in this window universal for available languages. To do this, I changed the structure of the help file by embedding the code so that the text is taken from the string file.
<moi:Text textid="SidePanel_v0">
In EN language everything works fine, but with RU encoding there were problems.
In the help file there is <meta charset="utf-8"> but apparently it has nothing to do with it.
I have attached a video:
Help me to solve it, Thanks
MoI_S5SPbmF9by.mp4
Hi Moi3dFan, what is the text encoding for your English_NoText_RuHelpStrings.txt file?
Is it saved in a Unicode format (like UTF-8 or UTF-16) with "Byte Order Mark"? If not then try that.
If that doesn't help please post the English_NoText_RuHelpStrings.txt file so I can reproduce what you show over here.
If a LanguageStrings.txt file has no byte order mark on it, it will assume that it's text in Windows-1252 format.
To avoid it from being processed as Windows-1252 format text, make sure the .txt file is saved in UTF-8 or UTF-16 format, with BOM (Byte Order Mark) set on it.
Oh, great! It worked!
Thanks so much
