Hi All,
My memory on this simple process is blown at the moment can someone refresh me on how to convert a spline to polyline with a set number of points. I am trying to find the script or process which I used some time ago and cant replicate it. Thanks in advance for any wisdom.
Hi Alex, try the ReconstructCurve script here:
http://kyticka.webzdarma.cz/3d/moi/#ReconstructCurve
Start with nothing selected and you'll be able to adjust the option for "Construct: Polyline" to generate polyline output.
Thanks Michael, Had that script been a while since I used it last and tried it about 20 times missed the select curve after running step - thanks for the reboot.
All going.
Reverse engineering Curves to simplify CNC output - this script nailed it.
Thanks to all that input into the MOI scripts.
