Full Version: Specific model and general milling preparation questions ?
Show messages: All  1-9  10-12
25 Feb   [#10] In reply to [#9]
I hope the next model help you
masthead base follow-up.3dm
25 Feb   [#11] In reply to [#9]
Hi Sven, ok thanks I think I understand better now.
Surfaces that barely graze each other and are also tangent can tend to be more difficult in surface/surface intersection calculations.
It will be easier for Trim to work on your cyan plane if you select the edges as the cutting objects rather than the full object, like this:
Then it should be cut up ok:
Also another way you can do it is to draw in 2 connecting lines like this:
Then select the lines and edges like this:
And then Construct > Planar can make a trimmed plane there:
sven_planar_1.jpg  sven_planar_2.jpg  sven_planar_3.jpg  sven_trim1.jpg  sven_trim2.jpg
25 Feb   [#12]
Thanks for explanation Michael. I realize that there are other solutions, just figured I had to be doing something wrong given the symmetry of model and it working one side, but not the other.
Thanks for the models vic.
Sven
