Good day.
I am drawing a kind of car fender ...practicing here.
How can I be able to do a smooth transition from the fender flare to the fender? I created with sweep after I cut it with the pipe script.
Attached a 3dm.
Also if I have a surface with allot of point how can I reduce the points count and how would I select a certain amount of points on a surface instead of starting outside the surface for selection?
You can hold down the Shift+Ctrl when you do the selection with the mouse. When both the Shift and Ctrl keys are being held down, MoI will immediately go into window selection mode and won't try to grab and move the object.
