5-24
25-31
@val2, How did you figure that out? Seems like that would be looking for a needle in a haystack
@Michael, Interesting. Thanks. Will read that in the morning.
Billabong,
Your model registered as solid in Moi but was failing so I looked at it in 123D. It came in with flipped normals but didn't show where the error was right away so I looked at it in Cad Assistant and it showed the two holes failing so I went to Moi removed the holes and cut two new ones. It then booleaned after that.
Val
@val2, Would you say it would be a good practice to periodically drop your model into CAD Assistant to check it for errors?
No, I only do it when things aren't obvious in Moi itself. As in, it looks like you have two solids but they won't boolean, so why not? have I confused Moi in some way? Are my control lines on my two objects touching? No? then I take it to another package to see if it can do it. It's a quick way to check errors. IE, 123D will show normals are not all facing out by assigning two colors to your model. If normals are not all facing out something is wrong with the solid. cad assistant will mangle the model so it will be obvious where things are wrong. Moi can on occasion do the same if you import from other software packages. what will come into moi mangled from lets say a solid works generated file will open up fine in 123D ( or, more to the point, open differently, some errors in moi won't be the same as the errors in 123D). I don't know exactly why but I suspect it has to do with each package calculating the model differently. You will need someone who understands this better to explain it.
@Val2,
So after a little bit of research on my end and realizing that the obvious was staring at me straight in the face. I figured out the main issue and I think the failure on my part was not fully understanding the jargon when working in nurbs. So after I brought in your file that you corrected for me, I started to get the same issue not long after where I couldn't get boolean to work. I kept sitting here thinking what am I missing. So, I exported out my model as an .obj into 3ds max, which is my native program. As soon as it came in, it looked like what you seen below. The normals were flipped!! I deal with cad from clients all day at my day job and there will be times when the model will import flipped normals even when importing as a step file and I never knew why. Actually I still dont understand why this actually happens in nurbs yet ( but I'm getting there). So I did a little more research and if I run my Cplane (in MOI) over the model, it actually shows me the patches that are flipped and then I can just select the patches, separate them and then press Tab, and write "flip" and then re-attach it to the main model. It fixes it.
This is a huge find for me. I was almost to the point of giving up because I just couldn't figure out why I was keep having this issue.
@Michael,
Do you know the reason why this happens? Part of me think that this comes from using "Mirror" but then it would also happen if I select an edge, duplicate it and create a patch from it using the network "command". Like in the image below. The funny thing is. All of those curves are "rebuilt" before the patch is created and the normals were still flipped. This is the main thing that I dont understand and is it something that I'm not doing correctly?
By the way, This is why when I would select only the faces that were going to be booleaned it worked is because those faces actually had normals facing in the right direction
Anyway. I know this was kind of a long post, but I wanted to post back what I found.
Annnnnddd. I just discovered another issue! After flipping all those normals in MOI and then reattaching them back to the main model. They re-flipped themselves!! I mean that went back to their original state!! Why?
Hi Billabong, probably there are some degenerate squished surfaces still in there. Surfaces that look like curves because they have all their surface area either squished down or trimmed away.
Those can interfere with surface traversal where things are trying to gather up stuff all on the same side.
@Michael, Found it! So this is an absolute nightmare. Is there a way to avoid this or a faster way to find this type of stuff? This can really throw a wrench in your production.
Hi Billabong,
It can be pretty hard to find these, sorry. To avoid it try to keep your initial curve setup as clean and simplified as possible, try not to have duplicate curves or little tiny segments in the curves.
Any irregularities in initial curves will tend to inherit on down the line.
If you have repeatable steps that generates some bad stuff please send it over to me so I can see if I can stop it from happening. It's really hard to figure out exactly what previous step went wrong only by looking at the end result.
Hey Michael,
I do have another question. but I think it would be easier to explain in a video. so I made this in hopes you could explain it to me. Thanks
https://www.dropbox.com/scl/fi/sm93yamauizuh91h6rbxt/Moi-Issue.mp4?rlkey=65t8sj1pbe4st2q1znsa55fzd&dl=0
Hi Billabong, can you please also post the .3dm model file that you are showing in the video?
It's pretty hard to figure out what is going on without being able to examine the actual geometry.
Thanks, - Michael
Sure thing. Sorry about that. Just a quick note, this happens every time I create a patch from existing faces.
patch_problem.3dm
Hi Billabong, you generally want to make things more by intersecting parts that push through each other rather than going around and filling in patches like this.
If you do want to fill in using Network, it will be tough to do it on edges that are meeting up a little loosely like you have here.
That's because to Join the new patch needs to have its edges match up close enough to the original edges, when you edit the curves that's basically moving stuff away from where Join will want it at. But just using Network without moving pieces isn't going to help because the surface that network generates will be an average anyway where things don't touch exactly.
Another complicating factor is a couple of micro edges in this area:
If you turn on surface control points on your Network, you'll see that even though the shape is very nearly planar, it's got a bunch of control points all sliding and skewing along like this:
This is not that great because you generally want surface control points to naturally follow the surface shaping and boundary details come from trim boundaries instead of baked directly into the surface structure.
I'll take a look at doing some repair work to simplify the edges.
Hi Billabong, some of the surfaces in here are a little odd, like this strip here:
That looks like it wants to be an extrusion that is trimmed but instead it's something that's surfaced directly between 2 long curves, unlike an extruded surface all of the surface control points are not all in one single direction there is kind of a skew between them in some areas.
I mean it's still a surface but it's more complex and less accurate than an extruded surface.
Hi val2
>I looked at it in Cad Assistant???
How do you open a .3dm file in "Cad Assistant"? I've read about opening Nurbs files but I don't understand how to do it.
https://www.opencascade.com/products/cad-assistant/
Additional mesh file formats import is supported with help of Open Asset Import (COLLADA, 3DS, FBX, BLEND) and openNURBS (3DM) libraries.
Well, I think that's way beyond my capabilities. But it may be of interest to some people.
https://github.com/mcneel/opennurbs
Zooen,
I import and export with STEP.
Basic functionality is provided by XDE component of Open CASCADE Technology (OCCT). The program supports the following file formats:
STEP (AP203, AP214 and AP242) — ISO 10303 standard for product data representation and exchange among CAD systems (ASCII format). Supported data: shape geometry, assembly structure, colors, names, validation properties, file information, dimensions and tolerances (semantic and tessellated PMI).
IGES (5.1 and 5.3) — vendor-neutral format for data exchange among CAD systems (ASCII format). Supported data: shape geometry, colors, top-level object names, file information.
glTF — API-neutral runtime asset delivery format (ASCII or binary), commonly supported by modeling systems and game engines. Supported data: shape geometry (triangulation), assembly structure, PBR metallic-roughness materials with texture maps, names.
XBF — BinXCAF, which is a binary persistence format for universal XCAF document structure used by OCCT. Format accumulates persistence of various data which can be imported from other files formats like STEP, IGES, ACIS, glTF, etc.
BREP — ASCII persistence of shape Boundary representation used by OCCT with open specification. Supported data: shape geometry and assembly structure (defined by nested compounds, without names).
OBJ Wavefront — format for 3D assets exchange commonly supported by modeling systems and game engines (ASCII format). Supported data: triangulation and quads, plain list of named groups, common materials with texture maps.
VRML or WRL — ISO 14772 virtual reality modeling language (ASCII format). Supported data: triangulation, assembly structure, colors, names.
@Michael,
This is becoming an absolute nightmare. I totally understand that its stemming from my lack of knowledge to achieve this in the proper fashion, but there isn't a lot of information out there on how to achieve good clean results with this method, unless you know of some tutorials or courses that go over this type of thing. I've watched almost all of Kuechmeister Swagger videos and he makes using networks and lofts look relatively straight forward, but its proving out that, that's not the case at all.
Hi Billabong,
It sounds like most of the problems are related to using MoI as a surface modeller rather than a solid modeller. In other words, trying to make a bunch of individual surfaces and stitch them together rather than making simple solids and using those as components or cutters.
Surface modelling is tricky, but Kuechmeister Swagger is really good at it and so makes it look easy. Like how professional athletes make scoring goals look easy.
For organic shapes that require surfacing there are some more tutorials here:
http://www.k4icy.com/tutorials.html
However, maybe starting over and sticking with solids for a while would help. Looking at your model it seems like much of it could be made by adding and subtracting simple solids and then filleting to blend them together.
- Peer
@pressure,
Your absolutely right, its just that surface modeling is what really interested me about Nurbs modeling to begin with. Solid modeling can be done in most 3d programs now with Booleans, so theres not much difference there, but regardless of that, I totally understand what you mean.
I have actually tried to go on k4icy.com tutorials, but when you click on any of the links to view it. None of the images show up anymore. All the links to the images are broken. So without them the tutorials are pretty much useless for me.
Hi Billabong,
Luckily MoI can do both surfaces and solids in the same environment and has operations that blend the two like using a surface as a boolean cutter for a solid.
Several of the problems that have come up sound like they stem from using Network when it's not the best tool for the job. Like when Michael said above that "That looks like it wants to be an extrusion that is trimmed but instead it's something that's surfaced directly between 2 long curves..." or also the nearly-planar surface that he pointed out.
So, instead of surfacing everything you could use solid operations for most things, and only surface when it's required. For the model you've been posting most if it could be done with solid operations from primitive solids like cylinder, sphere, revolve, or extrusion. For airplanes and cars there's lots of surfacing. But even when doing surfacing life can still be made easier by putting together solid "components" from the surfaces and then booleaning those together.
I understand you're already doing that, but the simpler each component is, the easier it will be to troubleshoot rather than looking for a needle in a haystack when trying to put a bunch of surfaces together at the same time.
For micro edges there's a plugin tool for finding them:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11271.13
The problem with surfacing is really that NURBS is a system capable of extreme accuracy. That sounds good, but it also means that it's intolerant of the slightest inaccuracy.
If you make solids that push through each other a little bit (overlap in 3D space) and then boolean them the overlap gives some slack to the boolean algorithms when figuring out how to combine the shapes.
Even when surfacing, it's best to use large surfaces that intersect so that the intersection can be used as the trim / edge. That get's rid of the accuracy problem by guaranteeing that the 2 surfaces meet along a common curve.
But, if you are going to build things up from surface patches you will need to work to the same in-human level of accuracy that NURBS entails. Like in your video, you move around some curve endpoints to get them to match up. That doesn't mean that the curves match up with the rest of the 3D object. And those tiny imperfections that are small on a human scale are actually large on a NURBS scale, so the software has no choice but to decide that the surface patches are too far apart to join.
- Peer
5-24
25-31
