Full Version: Shortcut for collapsing palettes for scene browser ?
4 Jan 2024   [#1]
Hi Forum. I tend to have scene browser "inside" pane to maximize drawing area. This results in a scene browser with little area for objects as I leave others panes expanded as I'm working. Is there a shortcut to collapse all palettes other than scene browser ? Anybody make an icon set that shows shortcut keys ?
Sven
4 Jan 2024   [#2] In reply to [#1]
Hi Sven, the scene browser "inside" mode is primarily intended to be used when you have a large monitor so there is a lot of vertical space available in the side pane.
You can set up this on a shortcut key to do that:
script: /* Collapse side pane palettes except scene browser */ var headers = moi.ui.sidePane.document.getElementsByTagName( 'moi:paletteheader' ); for ( var i = 0; i < headers.length; ++i ) { var header = headers[i]; if ( header.id != 'SceneBrowserHeader' ) { var tags = header.getElementsByTagName( 'moi:tabcontainer' ); if ( tags.length == 1 ) { tags[0].activeTab = ''; } } }
5 Jan 2024   [#3] In reply to [#2]
Thanks for script Michael, works great.
Sven
