Full Version: MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
Show messages:  1-18  19-38  39-58  59-78  79-93
23 Jan   [#19] In reply to [#18]
Hi Barry-H,
No, I am using my own tuned nodeeditor. If I can find out what is missing in my nodeeditor I can add that and I guess things will be fine!
And, thanks for the attached image, but I believe I did the very same thing yet no results! (the run button is not active!)
Here is the insde of the Macro
-Psygorn
23 Jan   [#20] In reply to [#19]
Hi Drillbit,
have you opened the macro yet ?
Barry
23 Jan   [#21] In reply to [#20]
Yes, I edited my previous post! Please take a look.
23 Jan   [#22] In reply to [#20]
Hi Drillbit,
it's as I thought its the display node.(In between Fillet to compare)
Just wire straight to the compare node and delete the display node.
Barry
23 Jan   [#23] In reply to [#22]
Hi Barry-H,
Now the run button is active but it does nothing! I open the nodeeditor and then select the curvepath and update Mulit Select
The Curve path turns into dashed line then I hit apply it disappears! And by closing the nodeeditor the selected curve path appears again.
Needless to say I tweak other nodes but nothing happens. and Even MOI Crashed!
- Psygorn
23 Jan   [#24] In reply to [#23]
Hi Drillbit,
so after running you get nothing ?
Open nodeditor before selecting any objects for some reason if you select and then open nodeditor it locks up.
It maybe that get by name is a better option but that's one path at a time.
Will investigate and let you know.
Barry
23 Jan   [#25] In reply to [#23]
@Psygorn - the crash could probably be mitigated by converting booleans to use processing in moi_commandprocessor.exe instead of in-process.
Like MO describes for fillets here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.348
23 Jan   [#26] In reply to [#25]
Thank you Michael,
as always!
- Psygorn
23 Jan   [#27] In reply to [#26]
Hi Drillbit,
multi select causes problems so change select method to select by name its more stable.
Make sure when opening Nodeditor no paths are selected for some reason this causes a lockup.
If there are close Nodeditor deselect and open Nodeditor again.
Barry
23 Jan   [#28]
Such settings cause a long and tedious wait.
24 Jan   [#29] In reply to [#28]
Hi WN,
the issue with the settings you used is the fillet needs to be larger than half box width.
I will add a mini fillet restriction to avoid this.
Barry
24 Jan   [#30]
Replaced file see https://moi3d.com/forum/index.php?webtag=MOI&msg=11314.51
24 Jan   [#31] In reply to [#29]
Hi Barry.
Thanks!
24 Jan   [#32] In reply to [#30]
Hi Barry,
I think now Rev Switch node doesn't work! (what is it or where should I find it?)
- Psygorn
24 Jan   [#33] In reply to [#32]
Hi Psygorn.
It can be thrown out and switched manually, it will work the same way.
24 Jan   [#34] In reply to [#32]
Hi Drillbit,
a link to where the Switchrevers is in my previous post.
It allows the ability to switch path curve to pipe or box.
I think this way only the required part is calculated.
Anyway give it a try.
Barry
24 Jan   [#35] In reply to [#8]
Barry-H,
Thank you for posting the updated nodeeditor zip.
I have been missing the Updated Display node for many months, due to having an old r2d3.js file in the node > extensions folder, (with nodes showing up in nodeeditor canvas under infos.)
The "newer" r2d3.js file shows a date of 3/9/23, and has 736 code lines.
This r2d3js file creates a new menu entry in nodeeditor canvas, (r2d3), with 9 node entries (currently).
25 Jan   [#36] In reply to [#20]
Hi Barry,
Yes, Pipe Macro & Box Macro both look fine to me!
RevSwitch on the other hand, does nothing (even when I double click it)
-Psygorn
25 Jan   [#37] In reply to [#36]
Hi Drillbit,
Switchrevers node diverts the path to pipe or box whichever one you want to produce.
Did you download it from the link I posted ?
Barry
26 Jan   [#38]
Hi Barry,
Many thanks for posting your NODE Pack - all working great really powerful node - what is the process of selecting multiple control paths to form the group of multiple selection?
Alex.
