Is there I way that I can get leading zeroes to be omitted from dimensions like ".100" instead of "0.100"?
This is required by ASME Y14.5 1.6.2(a): "A zero is not used before the decimal point for values of less than 1 in."
I thought it was just an arbitrary convention, but I've discovered that those leading zeroes take up a surprising amount of room and actually make it difficult to pack all the dimensions on a drawing. Sometimes I need to manually copy the "Value" of each dimension, paste it into the "Text" field, and delete the leading zero to get things to fit visually.
I guess Y14.5 says that leading zeroes must be omitted only from inch drawings because it's common for parts to have feature sizes less than 1 in, but not so common to have feature sizes less than 1 mm and also there are usually more decimal places in inch dimensions and so they take up more room.
- Peer
Hi Peer,
There is not currently any way to configure it to do that but I'll see about adding in an option for it.
That will be nice Michael. I'm looking forward to it.
- Peer
