Hi All,
The attached earring hoops have recesses for diamonds. I need to remove the recesses / fill them in.
What is the most efficient way of doing this please?
Thank you in advance.
Gunter
Hoop no holes.3dm
Hi Gunter, if you select the interior faces and delete them, that will leave an open edge and then you can select that and use Delete to do an "untrim" of the surface.
Looks like this:
... for everyone
https://disk.yandex.ru/i/6ga1Qggnc_rPgw
Cool multiple holes erasing!
@WN - thank you so much, this is brilliant!
Much appreciated!
Gunter
@Michael - As always thank you very much, this really helps!
All the best,
Gunter
