Show messages: All
1-5
6-10
Hi Finema, I'd probably focus on one leaf at a time and start with a flat pattern and bend it into shape using the Flow command. I'll see about making an example later today.
Hi Finema, so something like this - a 2D leaf in the top view:
Draw a line down the center of the leaf, and in a side view draw a bendy curve like this:
Select the leaf and run the Transform > Deform > Flow command, pick the center line as the base curve and the bendy curve as the target, that will make a result like this:
Repeat with some variations on the bendy curve, then rotate them:
The blue agave core has leaf bases which each look like a rhombus (squished square), not a hexagon.
Some of the upper leaves of the core could be left attached to the upper portion of the core. The lower 3/4 of the core would be grasp-able, so as to enable easy removal of the attached ground glass stopper ("cork").
-Brian
Above the ground glass "cork" could be a solid frustrum cone, big side up, with a representation of leaves in bas relief around the frustum, kind of like a crown. This would be grasp-able, and manufacturable, and safer than a bunch of breakable glass shard leaves, with less liability.
As an alternative to Michael's Flow method for creating the curves leaf shape, you could also Boolean intersect the leaf shape and a curve, like this:
Show messages: All
1-5
6-10
