Full Version: Water tap surface challenge
Show messages: All  1-4  5-20
12 Nov 2023   [#5] In reply to [#4]
So after Gordon... (Network)
12 Nov 2023   [#6] In reply to [#1]
Hi rhinouser141, usually it is best to make an initial structure that has sharp edges in it and use fillets to construct the transitions rather than trying to go around and fill in things "patch by patch".
12 Nov 2023   [#7] In reply to [#1]
So more like this:
Basically you don't want to try to directly construct transition areas, you initially want broad simple surfaces and then have extended transitions between them that are then trimmed to make the final outline as opposed to drawing in all the final outlines at the start and trying to fill in surfaces directly between.
Like for example this area here, you don't want to try and fill that in with a surface that follows that boundary area directly, it should be a transition surface that is extended and trimmed to the final edges, not directly constructed to the final edges:
water tap patch moi3d_2.3dm
13 Nov 2023   [#8] In reply to [#7]
Thank You very much Michael !!
13 Nov 2023   [#9] In reply to [#7]
i downloaded your file and tried to fillet with the 3 corners, also with different options, but i does not work.
Best regards
13 Nov 2023   [#10] In reply to [#9]
Try with the v5 beta: https://moi3d.com/beta.htm .
13 Nov 2023   [#11] In reply to [#9]
https://1drv.ms/u/s!AgF6VFezvIYcqyhvZX6hM3zr-8hj?e=xKtbjI
14 Nov 2023   [#12] In reply to [#10]
Thanks ! Not it works.
15 Nov 2023   [#13]
Functions Fillet + Blend :)
16 Nov 2023   [#14]
Thank You All for your input. With your ideas and tactics i managed to create a model which i like.
Feel free to download the file if needed.
Rendered in Keyshot.
Best regards
water tap final.stp
16 Nov 2023   [#15] In reply to [#14]
Congrats ! Well done !
Best regards
- Ken -
18 Nov 2023   [#16]
Great achievement, compliments!
25 Nov 2023   [#17]
The homework was handed in, I recorded a video of the modeling process, and the faucet was ready in no time. Share with you,
27 Nov 2023   [#18]
In Plasticity
27 Nov 2023   [#19] In reply to [#18]
Zarkow, it is not appropriate to post advertisements for Plasticity coupon codes here.
Thanks, - Michael
28 Nov 2023   [#20] In reply to [#19]
Yes, sorry, you're right, the commercial is my standard video description, I hadn't thought about that. I changed it to a OneDrive link without ads. Today I like to use both tools in combination.
