21-29
I have not said that : i have said Moi is the Rolls Royce of the Nurbs Modeling! :)
I you want see some cool old English cars made with Moi see MacGreggor!
http://moi3d.com/gallery/viewitem.php?id=1096
I am trying to find video tutorials of modeling cars with MOI3D AND NOT images of cars modeled with MOI3D.
I've seen plenty of images but there are hardly any videos WITH AUDIO NARRATION.
There are some video tutorials but they DO NOT have NARRATION, only CAPTIONS which I find very difficult to follow. One eye can not follow the mouse and the other eye follow the CAPTIONED text This is a very difficult task for me with my 70 year old eyes which are not as sharp as they were when I was in my 20s or 30s.
It's much easier to have both eyes on the video and both ears listen to the audio.
Cheers and thanks...
Is there any tutorials made by MacGreggor? I have seen his/her amazing works in the Gallery but no tutorial, thought u might know!
- Psygorn
No sorry MacGreggor don't make Tutorial!
except here this little one! ;)
https://moiscript.weebly.com/les-voitures-de-macgreggor.html
You can use the Google translate by address site page for any language!
You can find tutorials of car here click "original" ;)
https://moiscript.weebly.com/le-tuto-de-mauro.html
https://moiscript.weebly.com/fiat-abarth.html
https://moiscript.weebly.com/le-truck-de-ed.html
https://moiscript.weebly.com/la-voiture-de-ed.html
https://moiscript.weebly.com/la-vespa-de-mauro.html
https://moiscript.weebly.com/la-voiture-de-zarkow.html
Have fun car modeling! :)
Ps For old eyes some youtube videos by Zarkow has "general" text Captions!
Plasticity is definitely on my to buy list.
For what I do Moi is used probably 95% of the time in addition to other software.
For instance I use Vectric vcarve and it has its drawing tools...but I draw in Moi and then send to vcarve since it is way faster for me.
One thing I wish Moi had is a distort tool >
https://www.youtube.com/watch?v=-94OrLae_nY
Hi Matadem,
How is Distort different from using Flow like Michael suggested?
https://moi3d.com/forum/messages.php?webtag=MOI&msg=10114.453
If you want more than 4 control points you can do that by first drawing a grid of lines and then select the lines and do Construct > Network to make a plane. If you select the resulting plane and do Edit > "Show pts" you'll see the control points that you can then drag.
Is the problem that the result doesn't update in real time while you're dragging points?
- Peer
I hope @Zarkow will take a challenge and make his Benz using only MOI and new rebuild surface!
Tanx for the links Pilou :-)
Yep something like a realtime warp/distort would be nice.
Hi Matadem,
You can get the real-time distortion now by turning on History updating on the result of Flow. Be sure to do this immediately after doing Flow since even a tiny edit on any of the objects involved in Flow, like moving a point, will prevent history from working.
Select the objects resulting from Flow and then do Edit > History > "Enable update".
When you move edit points of the target point you should see distortion updating in real time.
History updating is turned on by default for some commands, but not for Flow. That's why you have to turn it on manually.
- Peer
21-29
