Show messages: All
1
2-3
Hi Pior,
> (in order to input the 4 points defining the axis or rotation and the desired amount of rotation at a glancing angle),
You can't get the last 2 out of the 4 points without leaving the viewport but you can type in your desired angle value instead of picking the 3rd and 4th points for it.
After you pick the first 2 points that set up the axis of rotation then type in 90 <enter>.
You can also set up a shortcut key where you can just pick the 2 axis points and automatically use 90 degrees without needing to type in that part.
To do that set this up on a shortcut key:
RotateAxis angleinput=90
Hello Michael !
Well, that's exactly it :D Much thanks as always !
I find it amusing that even after using 2pointrotate many, many times it never occurred to me to even look at the input field for the angle. I guess it can be seen a testament to how well-designed the tool is in the first place !
Thanks again.
Show messages: All
1
2-3
