Hi Micheal, I have problems with DXFs.
I don't know what could have happened, but Moi V5.0 crashes when I open this DXF file.
With V 4.0 works very well
I'm using moi3D in Linux with Ubuntu.
Greetings
001.dxf.tar.xz
Hi pafurijaz, I'm not getting a crash with that file in v5 over here.
Is there a crash dump file being generated over there?
I didn't have any problems before either, suddenly I can't open DXF files anymore.
I see now that there are some reports, but it closes immediately and doesn't create new reports.
I send you these maybe there is also something in these to check.
Thank you and greetings.
moi_report3.zip
Hi pafurijaz, I think I may have found the problem, I've sent you a private forum message with a test patch in it.
The DXF code had some old 32-bit memory alignment stuff in it, which is a error on 64-bit but often silently tolerated depending on processor and operating system.
