Show messages: All
1
2-6
Hi Andy, it's a lot more difficult for booleans to handle things that have coincident or nearly coincident surface areas.
So for your cut piece it would be good for it to be 2mm thick with 1mm going down like you have now but the other side 1mm above rather than flush.
Does it work ok if you get it set up like that?
Message 11022.3 was deleted
HI Andy, if you turn on control points for the curves you can see 2 red squares:
Those are spots that have several curve control points stacked up on top of each other. They may need to be cleaned up first.
Hi Andy try with this one.
Cap-BeforeBoolean-3_3dm.zip
Many thanks Michael - works great! Andy
Show messages: All
1
2-6
