If I use a monitor with 3840 x 2160 pixels instead of 1920/1080 is the quality of screenshots in this case better?
Hi Rudl, how are you doing the screenshots?
I make it with print on the keyboard
Hi Rudl, a better way to do the screenshot is by setting up a script on a shortcut key in MoI, as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1049.5
That generates an image basically to an internally allocated screen so it isn't limited by your actual monitor size.
Hi Michael, thank you very much.
I will try it tomorrow.
is it possible to enlarge the siz of the internally allocated screen. The picture has a size 0f 2560/2560 and I am not very happy with it.
Hi Rudl,
Yes, in the script code you can change the 2560, 2560 to something else. The upper limit will depend on what the video card driver supports.
Sometimes, I put certain variables in the front of the script, if I think I might need to change them.
My clipboard image script looks like...
script: /* CAPTURE RENDER */ var w = 3000; var h = 2000; var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 0; moi.grid.display = false; moi.view.meshAngle = 5.0; moi.grid.showXYAxes = false; moi.view.showHiddenLines = false; v.renderToClipboard(w, h); moi.view.lineWidth = 1; moi.grid.display = true; moi.view.meshAngle = 10.0; moi.grid.showXYAxes = true; moi.view.showHiddenLines = true; }
...and it's so easy for me to change the render size now. I just change
w and
h to whatever resolution I want.
Thank you. How can I find out, what my video card support.
Hi Rudl,
Well the main way is when you increase it and it doesn't work.
You may be able to find something like a maximum texture size on Windows using dxdiag.exe
I have a amd radeon rx 5700 xt
Hi Rudl, I'm not really sure where to find the maximum. You can just keep bumping it up by a couple of thousand and trying.
Thank you, I will try it.
