Show messages: All
1-5
6-11
that is absoutely awesome! Thank you very much. You just accelerated my workflow tremendously!
not works ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/not_work.3dm
Hi Pilou, it doesn't work on your case there because those are independent surfaces not joined to each other.
If you select those surfaces and use Edit > Join to glue them together into a connected object, then it should work.
Excellent!
You can click any face inside the loop!
here the last (or the first depending of your point of view! :)
Yes it is a great implementation by Michael. I already use it with shortcut and it is such a great addition to Moi. That workflow helps in many cases.
Show messages: All
1-5
6-11
