How can you make a hotkey command that exports a file with an specific name and path like for example, export .step to c:\transfer\transfer.step no questions ask, you just hit the key and it writes the file. I used to have this command but I don't remember where did I ask for, I don't remember how I did it. Thank for the help!
Hi Adam, you can set up this on a shortcut key:
SaveAs c:\transfer\transfer.step
That will save everything to that specified filename. If you only want to save selected objects and skip unselected objects then use Export instead, like this:
Export c:\transfer\transfer.step
Oh! thanks!, this tool is so simplistic! love it!
