8 Nov 2007
To: ALL
There is a new polygon wireframe to 3dm converter now available here:
http://moi3d.com/download/Obj23dmWireframe.zip
This enables bringing polygon data into MoI to use as construction guides.
Unzip it to some folder, and then you can run the Obj23dmWireframe.exe program.
It will prompt you for the name of an OBJ file, and after that the name of a 3DM file. It will read all the polygon data from the OBJ file and convert the edges of polygons into line segments, and save those line segments to the 3DM file that you specified. You can then load that 3DM file into MoI and use those line segments to snap on to.
- MichaelReply
8 Nov 2007
To: ALL
So it's not a volume 3D just a 2D plan lines?
So I must try it!
HIHI it's true volume! Works fine! The curious struture is given by a TopMod Model ;(so many facets are in double)
With the convector inside Moi : a sort of Helpers lines in 3D ;)
You can use it for make some plan facettes ;)
Reply
8 Nov 2007
To: ALL
I've tested it and it works well,thank you Michael, you support is absolutely amazing.Reply
8 Nov 2007
To: ALL
Great! Thanks Pilou and knightxor for testing it.
At least now there is some method to bring polygon data in.
- MichaelReply
8 Nov 2007
To: ALL
Hi guys!
This is great. Any way to control scale?
Reply
9 Nov 2007
To: ALL
Hi Michael, there's nothing built in to the converter to control the scale, it's pretty bare bones.
But you can scale it to whatever size you want inside of MoI - one easy way is to use File / Import to bring the .3dm file in - when you use Import instead of Open, the objects that are read in will be selected. So then they are all ready to use the Transform / Scale command.
After you run Scale, some shortcuts are to type in "0" and push enter to use the origin as the scaling point, and then type in your scale factor like 0.1 for 1/10 scale, and push enter. That should go pretty fast.
If you need to repeat that a lot, let me know and I can create a script macro for you to automate those steps.
- MichaelReply
14 Nov 2007
To: ALL
Interesting one ! Makes it easier to build some props for polygon models...
ThanksReply
16 Nov 2007
To: ALL
< At least now there is some method to bring polygon data in.
Why the planar function works for some lines in the same time (the squares are "separated" before) or even there are open surface (on the up left side)
and don't works for the big object? (file 3dm linked) Works only if I take manually the edges! (as shown in my previous post)
topo01.zip
Reply
16 Nov 2007
To: ALL
Hi Pilou, Planar is not set up to analyze curve structures that have more than two curves sharing the same endpoint.
In the case that you show with the separate lines, that is arranged so that each endpoint is only connected to one other endpoint. Planar is set up to track outlines connected like this.
When you have more than one endpoint shared, Planar may try to trace an outline like this:
So for example if it took that path above, it would not make a closed loop, so no surface will be generated there.
It would take quite a lot of extra programming work to make Planar be able to properly analyze branched structures like this.
- MichaelAttachments:
Reply
16 Nov 2007
To: ALL
Thx for precisions!
Reply
Reply to All
