3-22
23-42
43-51
Hi
Here is "Curve Array" node if someone interested.
CurveArray.js
Thx will be added to my repository! (If I understand its use! ;)
Thank you MO. Just added this new node file to AppData > nodeeditor > nodes > extensions folder.
So this is a Node version of the MoI command: Array (object along a) Curve.
It shows up under the nodeeditor Transform menu, as CurveArray.
Thanks a lot!
A missing node indeed :)
Hi
I rewrote the "fillet" and "chamfer" nodes.
They can now fillet or chamfer specified edges/faces Or entire object.
I also changed r2d3's "selectEdges" Node to make selecting edges easier.
Now it can pass the selected edges numbers(Indexes) (e.g. vertical/horizontal edges or holes )
Although it works best on solids.
Here is an example to show you how they work.
Node's address :
Construct/FilletEdges
Construct/ChamferEdges
r2d3/selectEdges
ChamferEdges.js
FilletEdges.js
r2d3.js
Excellent! Bravo!
"CoordinateFrames" node
Outputs:
Default coordinate frames (Up, Front, Right)
User defined frames
Address:
Points/CoordinateFrames
CoordinateFrames.js
"PlaneCenter" node
address:
Solids/PlaneCenter
"CurveMorph" node
This is the node version of "CurveMorph" script by Max Smirnov.
Morph between two curves
Inputs:
two curves
curves number
address:
Curves2/CurveMorph
CurveMorph.js
PlaneCenter.js
Cool!
"Array3D" node
Based on "Array3D" script by Max Smirnov.
Address:
Objects2/Array3D
Array3D.js
Excellent!
I will must add all these nodes on my repository!
That's wonderful! I am constantly amazed by the work of other MOI3D users!
Thanks!
Thank you guys
And thanks to max for his scripts.
I just realized that it's missing randomization, So updated my last post with the new node.
Have fun :)
"ConnectPoints" node
Address:
Curves2/ConnectPoints
"FatLines" node
Based on "FatLines" script by Max Smirnov
Address:
Curves2/FatLines
ConnectPoints.js
FatLines.js
Fat lines is a very cool function!
"Sum", "Average" and "RandInRange" nodes
Address:
Basic/Sum
Basic/Average
Basic/RandInRange
"RadialPattern" node
Based on Max Smirnov's "RadialPattern" script
Address:
Objects2/RadialPattern
Average.js
RadialPattern.js
RandInRange.js
Sum.js
Perfect!
MO,
Thank you for all your recent node contributions. It is gratifying to have the functionality of NE extended, however I think it is important to resist redundancy where at all possible.
You were perhaps unaware that there was a "Fatlines" node in existence contributed by Wayne. I see that you have added 2 speed modes, which may offer performance / fidelity improvements. Wayne installed his node under Construct2 directory which I think is the appropriate address.
As well, determining the average of a numArray is already provided by Max's "Extract" node. Could "Sum" be added to the "Extract" drop down menu?
As for your "planeCenter" node; this is essentially a replica of Kirsten's "SubD/SelCenterPlane" which is counterintuitively located in SubD directory; Solids is the appropriate directory. However, Wayne made a small modification to Curves/Rectangle node to output surfaces as well as outlines. I have found that in doing so, "SubD/SelCenterPlane" was already redundant. I am not sure if Wayne released Curves2/Rectangle2 to the forum, I believe he did, but anyway it is an elegant & coherent method to generating a plane. This is the perfect example of adding functionality to NE without adding bloat.
Your "RandInRange" has all the functionality of the original "Random" node, yet with the facility to operate within a chosen range and in so it is a worthy replacement.
I made some minor changes to the node's defaults so that it operates similarly to "Random" without connecting inputs. There are many application where only a single floating point number between 0 - 1 is required on running the node, as a consequence I have also made "digital" the default mode. I have attached revised code below, for your consideration.
I hope this post does not read as being critical of your contributions, quite the opposite; I am very happy that you have picked up the mantle, but only that it would be a better time investment to not be reinventing the wheel.
Keep up the good work,
RandInRange.js
Hi James
Thank you for your time and for these helpful suggestions. :)
About "FatLines" node you are right. I didn't know this node already exists.
Fast mode works just like the Max's "FatLines" script.
Slow mode gives different results on closed curves.
I agree with you, but sometimes it's more convenient to write a node than to finding it. :)
And sometimes redoing is because of having different NE versions.
Like this one:
My "Extract" node is a completely different node. :)
Generating a plane with "rectangle" node is nice, but I couldn't find "rectangle2" node.
Also in my NE version, "SelCenterPlane" node works just for one point.
Here is a timing comparison.
Mo,
That made me laugh:)
You have the correct Basic/Extract node, however it is a multi-function node. The numArray operations may be accessed by Right Button Clicking on the title bar. See below
There are a number of these multi-function nodes: Basic/Lenght for example.
I have attached below. Also attached are Circle2, Polygon2 & Star2
https://www.instagram.com/nodeology/Attachments:
circle2.js
polygon2.js
rectangle2.js
star2.js
3-22
23-42
43-51
