Show messages: All
1-2
3-4
Or also you can extrude them in the reverse order from what I showed above, like extrude this piece:
Then Trim it with the other flat profile:
You can also use Boolean intersection directly on 2 planar curves to generate this type of result, it will extrude them out for you automatically.
But it's kind of easiest to do something like this by creating a solid from all flat curves and then cutting away from the solid.
Thank you so much, as always you and the rest of the forum members are so generous with advise.
Thanks John
Show messages: All
1-2
3-4
