Show messages: All
1-2
3-6
Hi Michael, thank you for the reply. This is how I've been doing it until now but I was hoping to bind this to a key.
I've tried this - Ctrl+M - script:moi.geometryDatabase.selectAll(); Merge;
but I get an error message saying - ReferenceError: Can't find variable: Merge
Any suggestions? Thank you in advance!
Careful Merge is also a Boolean trimming function! ;)
Hi Peticel, the problem is that the contents for a shortcut key can either be a command name or it can be script code to run.
But in your case there you've got both of those together.
You'll need to put in this instead:
script:moi.geometryDatabase.selectAll(); moi.command.execCommand( 'Merge' );
Thank you, Michael. Works perfectly!
Kind regards,
Peticel
Show messages: All
1-2
3-6
