6-25
26-45
46-47
This is some information about the "calculateCurveOrientations" method. How it works and its properties. (Quotes from Michael)
You can generate an orientation list in script using:
var orient_list = moi.geometryDatabase. calculateCurveOrientations( ObjectListWithCurves );
This generates a list of CurveOrientation objects, one for each curve. Each CurveOrientation object has 2 properties .flipped and .seam .
The .flipped property will be true if the Blend should flip the curve before generating a blend from it, and the .seam parameter has a number value for the location of the seam point to use on a closed curve. The number is a normalized parameter value, a value of 0.0 means the start point of the curve, a value of 1.0 means the end domain of the curve.
Thank you Michael for clarifying this.
Thanks MO and Michael for this info! I've updated the .htm to include this
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
- Peer
6-25
26-45
46-47
