20-39
40-47
Hi Brian, from your link it looks like the blue flask button has this on it:
onbuttonclick="moi.filesystem.shellExecute( moi.filesystem.getAppDataDir() + 'moi_ref\\index.htm' );"
So when you click it, it should be looking for a file index.htm inside appdata\moi_ref .
You should probably double check if that is still what your button has on it and also double check if you've got your new file inside the moi_ref subfolder and that it is named index.
htm and not index.
html (no "L" at the end).
Thank you Michael.
Indeed, the recent MoI_v5API_Documentation, renamed to index,
had the .html extension, not the htm extension.
Now the documentation works with the BlueFlask button.
The very same incorrect extension that I have warned others of.
The files above at
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36 have been updated
The new version has a .htm rather than .html file extension
Added various stuff including a section for htm tags near the top. See changelog for details.
Brian: I think I made the corrections and additions that you suggested. Let me know if there’s anything else I should change.
Thanks to Larry and Michael for the new dump function! I did not expect just how useful it would be. A good chunk of the stuff in this update I discovered with dump().
- Peer
Wow Peer!
Just took a quick look at the doc and changelog...you've been busy!! This will be a lot of fun to go through the next time I have a script-itch to scratch, many thanks for your curiosity and effort here. I blush to receive any credit for dump(), I was just the irritant.
--Larry
The files above at
Factory inputs and examples added by MO. Thanks MO!
dump() function in Hints section at top has been changed to avoid a bug that caused the previous version to fail on objects with a null or undefined property value.
- Peer
The files above at
All factory inputs, properties, and methods have been updated due to extensive sleuthing done by MO and also a clever script devised by MO that automatically extracts the input properties of a factory. A version of MO's script that generates html is now with all the other files.
A bunch of factory examples added by MO.
dump() function in Hints section at top has been changed to avoid a bug that caused the previous version to fail on objects with an undefined property value.
geomObject properties and methods now up to date.
Big thanks to MO!
- Peer
This is some information about the "calculateCurveOrientations" method. How it works and its properties. (Quotes from Michael)
You can generate an orientation list in script using:
var orient_list = moi.geometryDatabase. calculateCurveOrientations( ObjectListWithCurves );
This generates a list of CurveOrientation objects, one for each curve. Each CurveOrientation object has 2 properties .flipped and .seam .
The .flipped property will be true if the Blend should flip the curve before generating a blend from it, and the .seam parameter has a number value for the location of the seam point to use on a closed curve. The number is a normalized parameter value, a value of 0.0 means the start point of the curve, a value of 1.0 means the end domain of the curve.
Thank you Michael for clarifying this.
Thanks MO and Michael for this info! I've updated the .htm to include this
- Peer
20-39
40-47
