Show messages: All
1-2
3-10
The Progression should have a base of 11, and a Factor of 1.
Going to work, no time to study now.
Javascript code:
https://www.geeksforgeeks.org/program-for-nth-fibonacci-number/
The nth term of an arithmetic sequence
https://www.alamo.edu/contentassets/afe30946fa58450c89840c1173f3b9d0/sequences/math1314-arithmetic-sequences.pdf
Maybe this can help
Left Click on the Title of the Math node for obtain Edit Properties!
Thank you for your detailed reply.
I think I gave a too regular examples. If the sequence is {1,8,20,b,c,... }, becomes {1,9,29,29+b,29+b+c,... }.
The point of the question is, I didn't use the loop node correctly or the loop node has bug.
But the sequence I want to generate is not limited to 5 or 8 numbers, and I hope to calculate more numbers.
I think maybe I didn't use the loop node correctly, or the loop node has bug.
When I'm dealing with objects or vectors, the loop node works correctly.
Hi all.
Try this.
https://disk.yandex.ru/d/TxQgdTTMVRMs2g
C:\Users\User\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Copy the file to this location using the link. This is for Windows.
Message 10850.8 was deleted
That's great. Thanks for sharing.
This is the node I really want.
Very compact! Excellent!
Show messages: All
1-2
3-10
