19-24
Hi Marek,
> When I try to execute this procedure I get an error as attached:
The relative point input needs a point coordinate, either an x,y value (which will use z=0) or an x,y,z value.
Also if your locale's number system uses the comma as the decimal separator then put it in as a space between the x and y coordinates instead of a comma between them.
So either r-5,0 or r-5 0 if you use commas as decimal separators.
Got it, finally!
The only way is to type in:
r-5 0
As both r-5 and r-5,0 return error.
This adds another functionality of sophisticated apps which cost at least 10 times more than MoI.
Thank you,
Marek
Finally found a recorder compatible with the "Trapezoïd" of the Helper Line ! :)
Click Move the Cline without release on the black rectangle edge
I take & write here 7 Enter ... after the calling Trapezoïd then move the Clines
(you can also move them only by eyes on the complete values)
Got you.
Thanks.
Small problem, you need 4 or 5 mouse clicks.
Gets bigger if you have more objects to relocate.
Yes but when you want a very precise distance...
2 Moves or r-x 0 which is the little gem is the answer.
19-24
