I'm having some very strange issues trying to use the planar command on an enclosed curve made of a couple arcs and polylines glued together with the join command.
I've got this curve here that I'm trying to make into a plane. It's fully enclosed, all one singular curve, and entirely two-dimensional:
But, when I try to fill it, or extrude it, I get this strange, inadequate approximation:
You can see here that the BREP is not being accurately represented by its sloping edge:
As you may have guessed, working with geometry like this down the line is next to impossible. This shape refuses to boolean or fillet. I have attempted multiple times to remake this curve with varying techniques, but have achieved similar results.
I've been asking a few questions recently, I'd like to take a moment here to thank everyone who responds to these. With that being said, Am I misunderstanding how solids work in MoI?
Thank you in advance.
Hi quat,
I think that it is a display artifact, due to display speed compromises.
Try Options > View > Mesh angle , lower value, say 2, or 5, ..
See Michael's response.
(Post a .3dm please)
Hi quat, that is just a display artifact where the display mesher did not generate a lot of triangles in that area.
It's purely a cosmetic display issue, it doesn't mean anything is wrong with your actual object.
That type of display glitch can tend to happen more when you have a shape that is only very slightly curved across a larger area, as you have here.
Just ignore that particular thing.
The shape refusing to boolean or fillet is due to some other issue, please post the .3dm model file so I can take a look at it.
That makes so much more sense now. Thank you!
Also, regarding the issues I was having with the geometry itself:
Taking a break and looking at it again made me realize that I had managed to repeat the same mistake each time I made the shape. I'd accidentally made the rounded front curve just barely non-tangential to the bottom surface, which made it stick out on the bottom a tiny bit. This seems to be what was causing the trouble.
Again, thank you for clearing this simple issue up. This forum is a life saver.
