Hello guys,
I just have two question as the tittle say:
1. How i can reset rotation of object?
2, How i can rotate object in specific Axis?
Robert.
Message 10835.2 was deleted
Hi Robert,
In MoI the rotation of an object is not stored as a persistent object attribute so there isn't anything to "reset". You can do things like snap on to key points on an object when rotating it to align it to a world axis direction. If you have a model where you're having difficulty doing that can you please post the .3dm model file with the object in it?
You can either use the regular Transform > Rotate command in an ortho viewport like the Top viewport for rotating around z, Front viewport for y, Right viewport for x, or use the Transform > Rotate > Rotate axis command and pick 2 points to define a rotation axis. If you have straight snap enabled when you pick the 2 points it will make it easy to align it along an axis direction.
