21-30
2 Psygorn (DRILLBIT)
I completely agree with you - it is impossible to make a fillet.
I do not understand - why and what is the problem! )))
Hi Krass.
I switched to other units of measurement and here is the result.
https://disk.yandex.ru/d/7bF1-_mvakjnWA
Hmmm... Very, very interesting.
I'll try it now, thanks!
I was mistaken, most likely it is a small scale, zooming in, for example, as here in the picture, allows you to make rounding.
In the original scale ...
it turned out only such a maximum fillet ...
By the way, about fillets in problematic and difficult places - I tried to test different variations of creation.
Velcome:
https://youtu.be/CztDikLAlb0
@Beemfarmer
About the ImgBox
- Download your image (s)
- Choose the Gallery wanted
- Start Upload
so...
you have just to copy to the forum...not very automatic...but very efficient and free unlimited..
and cool Gallery system! I use only Full size...
Hi krass,
> Michael, I don't know why, but I can't add images and files to the forum anymore.
> When added, it writes "Out of space" ... Where can I fix it?
> Sorry for being a little off topic.
There's a 50MB per user limit for attachments, otherwise it will be too easy for the server to get filled up.
On the top bar click "Options" and on the left side click "Attachments", and you'll be able to see a list of all your attachments and the sizes. If you have a large file attached to an old message you can delete it to free up some more space.
The other thing you can do is use a file sharing service like Dropbox, OneDrive, etc... where you upload your file to the service and put in a link to it here instead of directly uploading to the forum.
Hi krass, by the way it can help to conserve attachment space if you .zip up 3dm files that you upload.
> Next, on the solid on the right, I CAN continue doing fillets (red, top)
> And on the solid on the left - I don’t know why - I can’t make a single fillet anymore (even on the upper edge, like on the right)
> Question - what did I break?
There are some degenerate faces, meaning faces that have all their surface area cut away so they're collapsed to be more like a line than a proper face with surface area, in this region here:
Those can mess up various kinds of volumetric calculations in somewhat unpredictable ways. In the attached model I've removed those and you should now be able to resume working on it.
fillet_test_03_fixed_3dm.zip
Thanks Michael! I will study your model!
Sorry for distracting you again with my trifles))
21-30
