4-23
24-43
44-62
Hi James, yeah I wasn't sure if the sketchy cross hatching would combine ok with the exact silhouettes but it seems fine together.
Michael
hi Pilou,
> So it's that sort of effect that you want but made in Moi3D ?
Yes, similar but with vector lines and curves being output, not as an image processing effect.
Ok! :)
these hatching must also following the lighting of the object or must be isotropic ?
(from your examples seems isotropic)
It's possible to do either.
The ones here adapt to lighting and have denser lines (smaller spacing) where the lighting is dark:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10774.2
This one does not respond to lighting:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10774.19
That will be an option that you will be able to set.
ok...
Else in theory Flow function can't be used ?
Not if you want it to look like real hatching - the pattern flowed on a sphere will be compressed at the pole areas and wider at the equator.
Yes but you can make some Flow after a rotation of the sphere!
Sure the hatching will be not ultra regular but...
Hi Pilou, that's too dense with too many lines crossing each other. It should only have 2 lines crossing each other at any single point like this:
Congrats!!
Maybe look at a "max length" type of value that can get rid of the "tidbits"... the little "outlying flyers"....
Thanks Burr! Yup I was also thinking of a minimum cutoff size parameter to cull stubby pieces.
Righteous!
I feel your excitement! Like it's a long lost pal...
I wish you more of those to come this year!
Thanks Burr, yup it's true I'm pretty excited!!
Failed test
Getting more under control. Here with shading aware spacing and breaks at specular highlights.
Hi Michael!
...very interesting!
Keep it rolling :)
Have you a ready made Hatching repository ?
There will be some parameters you can adjust. Not a whole lot, probably for spacing, whether spacing varies with shading, hatching direction both, min curvature, or max curvature and whether to screen out small curves.
Cool!
Can we apply this on several faces of volumes and not only on the full volumes ?
No, probably not.
Not a big deal, just select the face(s) unwanted and make any erase/replace you want! :)
4-23
24-43
44-62
